462 /6x4 heads /211/177 SS valves/ been ran on dyno .
462 /MILD CAM / ASSEMBLY IS balanced/forged pistons/Rods/ NEW= DIST.(DUI)/ STOCK 1972 int. with A FRESH 17057274 0267 ARN 800 CFM Q/JET. / SS/211-177 VALVES/ 6QT. OIL PAN WITH 1 PC. FRT.AND REAR CRANK SEALS ALONG WITH 1 PC. OIL PAN. (BUTLER )RARE EX MANIFOLDS WITH DOWN PIPES /ALL IS (NEW) EXCEPT REBUILT/Q-JET AND THE BALANCED CRANK . 5500.00 will help with shipping but prefer pick up and can save $$'s for pick up . Please email or PM for pics and info !
I'm curious, what kind of dyno numbers.
_____________________________ She woke up sunny side down and I was still thinking I was too proud to flip her over |
The # 5 run was just at 4800 rpm and it was at 488 T /360 HP. I was just after a few runs to make sure it's broke in and no problems so if I had some one install it for me we wouldn't have to do it more than once ! I didn't have plans of selling it I actually built it for my own use . I put all the new xtra performance parts in it for strength and durability . I'm sure for a few different parts installed it would be more HP/Tq. so it's built strong enough for additional improvements if desired ! If you can give me an email address I can send you the last sheet of dyno !
AVAILABLE
The block # is 485428, 455 bored 30 over (462) completely rebuilt / Line bored/Honed/0 Deck and squared! Internal Parts as follows: SP.030 TRW L 2359 FORGED PISTONS ON RPM FORGED I-BEAM RODS W/ 7/16 ARP CON ROD BOLTS ! COMPLETELY BALANCED WITH NEW HARMONIC BALANCER AND NEW HAYES FLEX PLATE! THE (6X4) HEADS HAVE BEEN TOTALLY REBUILT AND MACHINED FOR POSITIVE VITON SEALS ALONG WITH ENLARGING THE EXHAUST VALVES TO 1.77 /2.11 INT. (STAINLESS STEEL) ! THIS SHOULD END UP WITH A COMPRESSION OF APPROXIMATELY 9.5 TO 1 ! ALSO HAS ALL NEW SPRINGS/ROLLER TIP ROCKERS AND NEW PUSH RODS . THE ONLY PARTS THAT HAVE BEEN REBUILT AND NOT (NEW) IS THE 850 CFM Q/JET AND THE ORIGINAL 455 CRANK THAT WAS RESIZED AND POLISHED ! (NEW BUTLER ) (6 QT ) OIL PAN /DIP STICKS/TUBES W/60# PUMP AND 1 PIECE OIL PAN GASKET /VITON CRANK SEALS./ (RARE) EXHAUST MANIFOLDS. WITH MANDREL BENT DOWN PIPES (FIT 2ND GEN BIRDS AND MANY OTHERS) I ALSO USED THE 1972 STOCK CAST INTAKE FOR EX FLOW AND CORRECT HOOD CLEARANCE FOR FIREBIRD ! THE CAM I USED IS A ELGIN E 980 P /I HAD A 979 IN A PREVIOUS 462 IN MY 76 BIRD AND IT WAS VERY STRONG SO I BUMPED IT UP 1 MORE # ! STILL POWER TO BE MADE WITH UPGRADES TO CAM AND ALUM HEADS WITH A BOTTOM END TO HANDLE IT !!!!! THE PICS SHOW THE ENG . PLEASE LOOK IT OVER AND GET BACK TO ME WITH ANY MORE INFO AS NEEDED, THANKS FOR LOOKING
Here's some specs related to this engine !!! 5500.00 AVAILABLE |
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX AVAILABLE XXXXXXXXXXXXXXXXXXX
This is AVAILABLE XXXXXXXXXXXXXXXXXXXXXX PICK UP AVAILABLE ONLY ( 4900.00)
SOLD
Thread Tools | |
Display Modes | |
