Endura bumper repair kit 3M 5896
Many threads point to the 3M 5896 repair kit to fix gouges in the rubber endura bumpers. The info online mentions for plastic repair, but says nothing of rubber. Regardless, is this the correct item to use with best results? I see many places say it's out of stock. Not sure if that means it's a popular product or being discontinued. It seems pretty spendy at about $80 for 13 oz.
That is the correct product, but the #5896 is the large squeeze tube kit and I believe it may be discontinued. 3M makes that same product in a smaller squeeze tube kit under #5895, as well as the Easymix #5887 twintube packaging but you need a special gun to squeeze it out. The 3M products are not cheap but they are very high quality.
The product doesn't mention rubber, but what you need to look for is "epoxy based" and "flexible repair". According to the Bodyshop forum, the things you DON'T want to use are urethane based products, polyester based products, or anything listed as for rigid or semi-rigid repairs. Epoxy based + flexible is what you want. Also note that 3M owns the Bondo brand and they offer an epoxy flexible repair kit in small tubes under the part # 806C. I have tried the all three of the 3M versions I referenced above, as well as the Bondo version and they all work well but the 3M products were noticeably easier to sand. The Bondo tubes are also quite small so if you have a lot or repairs to do you will need several kits. There are other manufactures that produce a comparable product (Norton, SEM, etc.) but I have never tried those. Note that I am not a body man, just a hobbiest...
Michael Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done... |
The Following User Says Thank You to mrennie For This Useful Post: | ||
The 806c is what I used and it worked great. It cures to a consistency and color exactly matching the raw endura...except it sands a lot easier.
Greg Reid Palmetto, Georgia |
Thanks for that info.
I found a listing for the Bondo 806, but not 806C. I wonder if they changed the formula and then dropped the C. Last edited by tjs72lemans; 12-22-2019 at 01:35 PM. |
I use the 3M 5895 (part number 05895) for all my endura repairs. Yes it's pricey but the results cannot be argued.
Then I prime with PPG DP48LF with an epoxy primer after sanding with 180.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear 85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book. 87 F350 6.9 4 speed dually A poor man has poor ways. |
Thread Tools | |
Display Modes | |
