Checking pushrod length with hydraulic roller lifters
I’m to the point with my 428 build where I need to check for proper pushrod length. Block has been decked, hydraulic roller lifters and new Edelbrock heads that have been prepped by Butler Performance.
I really don’t want to buy a set of solid roller lifters and I’ve read multiple times over that solid rollers have a different roller to cup height anyways. I am going to be running Johnson short travel lifters that have 0.058” of travel and they are currently soaking in oil. I also installed checking springs for cylinder 1 springs. Will the hydraulic lifters be alright to check pushrod length with them soaked in oil and the checking springs?
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
There’s a good thread here recently about this subject, I will search for it and bring it to the top...
Pushrod length and half lift method, I brought to top...
