Old 11-18-2012, 12:09 AM
400 plus's Avatar
400 plus 400 plus is offline
Default Flex-plate install
I have a after market flex plate. It has a SFI tag. Wondering which way to bolt to motor. With the tag toward motor or toward the trans. The ring and flex plate is flat on what I consider the back with the tag that is on the side that is dipped in a 1/4 inch. Took a pic but my FB account isnt working. Thanks in advance
Old 11-18-2012, 12:28 AM
It will only go on one way, the crankshaft flange bolt pattern has one offset hole so you can't bolt it on backward.
The only way to bolt it on backwards would be to use only 5 of the 6 bolts.
Old 11-18-2012, 12:38 AM
400 plus's Avatar
That makes it easy! Thank you!
