73 400 short block and heads
I have a 73 400 short block and heads. All from same engine. I pulled the heads and took it to the machine shop, and I haven't started anything with it yet.
It has never been opened up before and looks real good inside . It was a running engine pulled several years ago. It still turns over, just has very light rust beginning in the a few cylinders. It would probably clean up at .010 with no trouble. Casting number 481988 Heads are 4X-7 and I have CCed them.They are 98 CC chambers. This motor had good antifreeze running out when I picked it, and is pretty clean inside. I was going to build a stroker with it which would be real ideal with the 98 CC heads made for unleaded gas.(Had 4 bbl. EGR intake on it too) Sale is for heads and assembled used short block. No pan, valley pan or intake etc. I do have timing cover and balancer to go with it as well as the head bolts and miscellaneous bolts if needed. It was a 4 barrel engine. I don't have the block code handy, but I will post It in a few days Asking $ 950.Negotiable. PM me , Or E mail me at lascantech@aol.com Located in Northeast Pennsylvania 17765 zip code This motor would run if just re assembled , but is sold as an exceptional core for the sole purpose of rebuilding. |
still available.
Bump
Bump
Bump. Still have this 73 400 engine complete. Unmolested. I took the heads off, and removed timing cover as I was going to take it to the machine shop.
As stated this was a running engine when I got it to use as a buildable core. Never been disassembled |
