Old 10-25-2023, 10:02 AM
patox's Avatar
patox patox is offline
Send a message via MSN to patox
Default Column shifter indicator on my 70
Hi, my new to me 70 has a column shifter and a weird indicator I've never seen before, not even in pictures I googled..
The column does not seem to be missing any indicator, the top of it is perfectly round, no bolts or whatsoever and the indicator works, but just points to the air.
Maybe its perfectly normal, but I dont know...
Also no idea what that silver cover is for on the left side of the column either..
Hope someone can chime in!
Old 10-25-2023, 10:15 AM
bluejudge bluejudge is offline
I do not have a column shift, but I think you are missing the indicator letters that go over the arrow. PRNDSL. I am sure someone with a column shift will add to this. Good Luck, Marc.
Old 10-25-2023, 12:22 PM
400 Lemans's Avatar
https://www.ebay.com/itm/133861270845 Your missing the plastic piece with the lens. Mounts where the silver cap is. Maybe broke off or not. Check the pics.
Old 10-25-2023, 12:27 PM
patox's Avatar
That makes a lot of sense... never saw it that way.
Thanks!
Old 10-25-2023, 04:40 PM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
silver bullet lights up the prndsl indicator.
Old 10-25-2023, 06:46 PM
SD455DJ SD455DJ is offline
Like Indymanjoe said, the PRNDSL bezel covers the light housing on the left side where it drops down on the column.
Dennis
