Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Cylinder head coolant plugs
Received mine today.
Excellent Thanks Rich! Ron Bolanowski
Another Red Light Nightmare 1966 Martinique Bronze 2+2 428 tri-power auto, black top & bucket seat interior, pass recliner, ATC, Cruise, AM FM, Reverb, Wood wheel, tilt, ps, pb, pw 1966 Catalina, Barrier blue with a white vinyl top, tilt, AC, ps, pb, bucket seats with console 68 428 4 bolt, 4 speed M20 and a 66 tri-power project. Semper Fi |
Thanks to all my Pontiac friends who bought a set of coolant plugs for the rear of the cast heads, i made 8 sets and all sold with great reviews from e-mails to me,Keeping it simple and easy was my goal and it worked,I am in the process of making 2 more sets. Anybody with interest please let me know and ill make and hold a set for you. Thanks again everyone and enjoy & have fun!!
67, I'm interested in a set. Do you think these would fit with a 90 attached in between the firewall and the head? It's the same size plug I think.
PM me with payment options. Robert |
The attached photo is set up for KRD heads where the hole is thredded.
Its ok to giggle and snicker, Dont laugh and point |
Coolant Ports
Robert |
Explanation
For those of us not into racing can you tell us what exactly these do and what heads they fit? Stock or Aluminum aftermarket. Got the hint they helped with heat across the heads but not sure.
What is the cost for a set? |
I was bored, so I snapped a few pictures to show what they are and what they do
You don't need to be into racing for them to work/help, but it'll take a day or two for you to get the setup together. These are in stock 6x heads. I don't have a before/after of how well they work, but I've heard 15 degrees. If it's 5 degrees, though...i think it's probably worth it (if you have spare time and $ on your hands) More importantly, i wouldn't doubt that they even out some temperatures between the front and rear of the head. Might also have value...beside the temp drop in the motor His little aluminum plugs just push into the holes on the heads. And then you thread AN fittings or whatever else you like into them. Screw right in...and add your plumbing I went with braided lines and AN stuff....took quite a while to measure, cut, etc But kinda neat get setup with paypal, cruiser...and I'll take a set or two I'm too lazy to send a money order out. Ironic that i have no problem spending 10 minutes taking pictures, uploading pictures, etc etc But far too lazy to write a name on an address and drop it a mailbox somewhere
Clay Marsh 1967 GTO convertible Twin Turbo 5spd project http://forums.performanceyears.com/f...d.php?t=618281 http://www.youtube.com/watch?v=eJ9KworCMRE Last edited by baron_; 09-28-2009 at 03:03 PM. |
Two Question remain
OK
1.) when can I get a set 2.) How much for a set? Kirk |
2 sets left, i need to buy more aluminum stock!! I am holding the price to 20.00$ a set, 1.50 for the shipping envelope plus shipping costs to your house!! Yes they simply push into the rear of CAST heads after removing one soft plug and the heater nipple. once inserted screw 90 degree fitting in and head to the front of the water crossover, i put mine under the crossover, WHAT A DIFFERANCE!! mine is at least 15 degree,s cooler. One guy e-mailed me and said his was 20 degree,s cooler?? All i know is that they worked for me!!
Thanks everyone. |
I sent PM to buy a set. I intend to use the RUSSELL PERFORMANCE TWIST-LOK HOSE 5/8 Hose and will look at the avenues to route it.
Would a one way valve be worthwhile so the pressure just flows one way or what have you guys seen? I have a aluminum valley pan and a Huricane intake so there will be no hot cross over underneath. |
any of these plugs left ????
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-Moser rear-Dougs Headers.... |
pm sent
37 Pontiac Sedan 455 700r4 94 Firehawk Supercharged 5.7 LT1 6spd. 77 Grand Prix base model, 350 pontiac 97 F250 7.3 turbo diesel 85 CJ7 Laredo 65 Impala SS 396, 4 spd, A/C. |
Wanted to bring this post back to the top as it has more info than the later one. Can anyone tell me if they have a diagram of coolant routing in a normal pontiac engine/heads? I'd like to see how this alters it.
What size hose is recomended? 8 or 10 ?????
Which way does the water flow with these in the engine? |
No.8 hose for 1/2,Thanks everyone again for your support!!JUST SOLD ANOTHER SET!!
Since these are just an enhancement to the cooling wouldnt #6 work? Just trying to devise a system that is functional and looks OK.
just a note i got the plugs over the weekend very nice workmanship
#38
Anyone have any pics of how they incorporated the heater core in their configuration?? This is WI so heater cores are required by state law Last edited by pontiac_banshee; 05-15-2010 at 10:56 AM. Reason: Poor Spelling :) |
#39
I have heard of guys running a no. 6 line, but to be truthfull 12 sets sold and one set for the no.6,s line made, i think no.8 is the only way to go!!~
#40
How about Cooler
How would this work with a small tranny size cooler attached to it? Maybe mounted to the firewall? Would the water flow between or does it have to be connected to the front crossover?
I am trying to find a way to incorporate it with the heater core still as I am after all in Wisconsin so I cant just bypass it. Anyone have any thoughts on adding it to a cooler???? |
