Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
for sale garage sale
- Moroso split billet rail aluminum Pontiac Langer pan, wet sump, BOP belt drive front, rails bent from giant wheel stand, still seals to block, used, $350
- Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $500 - LSM 55mm soild roller cam, LS1 firing order, made 1165hp on BES dyno, lots of lift and duration, used, $350 - GRP aluminum rods, set of 8 w 50 runs, 2.100 rod, .990 pin, 6.750 or 6.800 long (i forget) used, $200 - BOP cast aluminum 4500 intake manifold, unported w/ thick flanges for multiple head designs, New, $400 - Crower .904 solid roller lifters w/ tie bar w/ Pontiac oiling mod plus a bunch of spares equaling close to another complete set, used, $250 - Cometic MLS head gaskets Pontiac V8 up to 4.360 bore w/ .040 h/g ICTC water spec H2268sp4040, New, $150 for the pair - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $80 - fluidampr Pontiac balancer, used, $250 - moroso 2 groove aluminum crank pulley 4" OD machined to fit above balancer, outer groove is dented, used, $30 - HVH super sucker SS4500-1.1 plastic 1" for 4500 dominator carb 2.125", used, $75 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $140 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - Barry Grant BG280 fuel pump, used, $150 - Barry Grant BG400 fuel pump w bracket and one AN fitting, used, $180 (looks new) - barry Grant 4-port + fuel pressure regulator #140023 w bracket, new, $90 - (3) Barry grant 4-port pressure regulator brackets $10 ea - 5-gallon poly fuel cell w -8 outlet and missing other outlet fitting, -8 retuen missing vent fitting, used, $50 - Moroso aluminum 727 proflite trans pan w drain plugs, bottom side dinged up from wheel stands, used, $80 - B&M pro ratchet shifter cover, aluminum for 3-4 speed auto trans, new, $40 - Hurst quarter stick 3-speed forward pattern w cable, no knob, used $120 - 4.86 9" moser pro gear, back cut and lightened, used, $150 - Moser pinion yoke, steel for 9", large pinion, used $70 - (2) Moser pinion supports w bearing, large, used $75 ea - Autometer pro tech series playback box, used, $50 - Simpson cam-lock 5 way harness, black, great shape, out of date, $75 |
sent pm
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
Pm sent
I'm interested in the bg400 pump. Can you check shipping to 60164. Thanks John
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
it would be coming from 19115, cant check shipping prices from work computer.
I have had around 10 PM's on the oil pans, I have a friend that will send pictures tonight that asked for them.
I callled at 6:15 am for pics none yet glad your car is faster than email.. 8)
77 Trans Am All Steel, on 10" tires 8.30 @ 165 mph 3,380 LBS Mat it! Spray it! Chute it! Just another 8 Second Pass! |
Here is a link for some of the pictures of John's parts:
http://lethaldeals.com/?page_id=275 Let me know if you need more. I am taking care of selling and shipping these items. I can quote you shipping prices just PM me. John can answer your questions about the parts.
- Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $500 - LSM 55mm soild roller cam, LS1 firing order, made 1165hp on BES dyno, lots of lift and duration, used, $350 **SALE PENDING** - GRP aluminum rods, set of 8 w 50 runs, 2.100 rod, .990 pin, 6.750 or 6.800 long (i forget) used, $200 - BOP cast aluminum 4500 intake manifold, unported w/ thick flanges for multiple head designs, New, $400 - Crower .904 solid roller lifters w/ tie bar w/ Pontiac oiling mod plus a bunch of spares equaling close to another complete set, used, $250 - Cometic MLS head gaskets Pontiac V8 up to 4.360 bore w/ .040 h/g ICTC water spec H2268sp4040, New, $150 for the pair **SALE PENDING** - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $80 - fluidampr Pontiac balancer, used, $250 - moroso 2 groove aluminum crank pulley 4" OD machined to fit above balancer, outer groove is dented, used, $30 - HVH super sucker SS4500-1.1 plastic 1" for 4500 dominator carb 2.125", used, $75 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $140 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - Barry Grant BG280 fuel pump, used, $150 - Barry Grant BG400 fuel pump w bracket and one AN fitting, used, $180 (looks new) - barry Grant 4-port + fuel pressure regulator #140023 w bracket, new, $90 **SALE PENDING** - (3) Barry grant 4-port pressure regulator brackets $10 ea - 5-gallon poly fuel cell w -8 outlet and missing other outlet fitting, -8 retuen missing vent fitting, used, $50 - Moroso aluminum 727 proflite trans pan w drain plugs, bottom side dinged up from wheel stands, used, $80 - B&M pro ratchet shifter cover, aluminum for 3-4 speed auto trans, new, $40 - Hurst quarter stick 3-speed forward pattern w cable, no knob, used $120 - 4.86 9" moser pro gear, back cut and lightened, used, $150 **SALE PENDING** - Moser pinion yoke, steel for 9", large pinion, used $70 **SALE PENDING** - (2) Moser pinion supports w bearing, large, used $75 ea **SALE PENDING for 1** - Autometer pro tech series playback box, used, $50 - Simpson cam-lock 5 way harness, black, great shape, out of date, $75 |
Larry you have a pm.
SALE PENDING on BG400 Fuel Pump
Sale pending on lifters
Sale pending on BOP intake |
Updated list, some updated prices
- Moroso split billet rail aluminum Pontiac Langer pan, wet sump, BOP belt drive front, rails bent from giant wheel stand, still seals to block, used, $300 - Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $450 - LSM 55mm soild roller cam, LS1 firing order, made 1165hp on BES dyno, lots of lift and duration, used, $350 **SALE PENDING** - GRP aluminum rods, set of 8 w 50 runs, 2.100 rod, .990 pin, 6.750 or 6.800 long (i forget) used, $150 - BOP cast aluminum 4500 intake manifold, unported w/ thick flanges for multiple head designs, New, $400. **sale pending** - Crower .904 solid roller lifters w/ tie bar w/ Pontiac oiling mod plus a bunch of spares equaling close to another complete set, used, $250. **sale pending** - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $80 - fluidampr Pontiac balancer, used, $250 - moroso 2 groove aluminum crank pulley 4" OD machined to fit above balancer, outer groove is dented, used, $30 - HVH super sucker SS4500-1.1 plastic 1" for 4500 dominator carb 2.125", used, $75 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $100 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - Barry Grant BG280 fuel pump, used, $150 - Barry Grant BG400 fuel pump w bracket and one AN fitting, used, $180 (looks new) **SALE PENDING** - (3) Barry grant 4-port pressure regulator brackets $10 ea - 5-gallon poly fuel cell w -8 outlet and missing other outlet fitting, -8 retuen missing vent fitting, with mounting brackets used, $50 - Moroso aluminum 727 proflite trans pan w drain plugs, bottom side dinged up from wheel stands, used, $80 - B&M pro ratchet shifter cover, aluminum for 3-4 speed auto trans, new, $40 - Hurst quarter stick 3-speed forward pattern w cable, no knob, used $120 - Moser pinion support w bearing, large, used $75 - Autometer pro tech series playback box, used, $50 - Simpson cam-lock 5 way harness, black, great shape, out of date, $75 |
Updated list
- Moroso split billet rail aluminum Pontiac Langer pan, wet sump, BOP belt drive front, rails bent from giant wheel stand, still seals to block, used, $300 - Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $450 - GRP aluminum rods, set of 8 w 50 runs, 2.100 rod, .990 pin, 6.750 or 6.800 long (i forget) used, $150 - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $80 - fluidampr Pontiac balancer, used, $250 - moroso 2 groove aluminum crank pulley 4" OD machined to fit above balancer, outer groove is dented, used, $30 - HVH super sucker SS4500-1.1 plastic 1" for 4500 dominator carb 2.125", used, $75 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $100 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - Barry Grant BG280 fuel pump, used, $150 - Barry Grant BG400 fuel pump w bracket and one AN fitting, used, $180 (looks new) **SALE PENDING** - (3) Barry grant 4-port pressure regulator brackets $10 ea - 5-gallon poly fuel cell w -8 outlet and missing other outlet fitting, -8 retuen missing vent fitting, with mounting brackets used, $50 - Moroso aluminum 727 proflite trans pan w drain plugs, bottom side dinged up from wheel stands, used, $80 - B&M pro ratchet shifter cover, aluminum for 3-4 speed auto trans, new, $40 - Hurst quarter stick 3-speed forward pattern w cable, no knob, used $120 - Moser pinion support w bearing, large, used $75 - Autometer pro tech series playback box, used, $50 - Simpson cam-lock 5 way harness, black, great shape, out of date, $75 |
Updated list
- Moroso split billet rail aluminum Pontiac Langer pan, wet sump, BOP belt drive front, rails bent from giant wheel stand, still seals to block, used, $275 - Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $425 - GRP aluminum rods, set of 8 w 50 runs, 2.100 rod, .990 pin, 6.750 or 6.800 long (i forget) used, $150 - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $80 - fluidampr Pontiac balancer, used, $250 - moroso 2 groove aluminum crank pulley 4" OD machined to fit above balancer, outer groove is dented, used, $30 - HVH super sucker SS4500-1.1 plastic 1" for 4500 dominator carb 2.125", used, $75 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $100 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - Barry Grant BG280 fuel pump, used, $150 - (3) Barry grant 4-port pressure regulator brackets $10 ea - 5-gallon poly fuel cell w -8 outlet and missing other outlet fitting, -8 retuen missing vent fitting, with mounting brackets used, $50 - Moroso aluminum 727 proflite trans pan w drain plugs, bottom side dinged up from wheel stands, used, $60 - B&M pro ratchet shifter cover, aluminum for 3-4 speed auto trans, new, $40 - Hurst quarter stick 3-speed forward pattern w cable, no knob, used $100 - Moser pinion support w bearing, large, used $75 - Autometer pro tech series playback box, used, $50 - Simpson cam-lock 5 way harness, black, great shape, out of date, $75 |
Thanks John and Larry I got the pump yesterday.
No problem. Thanks for the purchase.
I've had a few questions recently about the split pan. Let me clarify. It bolts flat to the block. The billet split rails bolt and seal together they are just bent. This means you can not use studs in every hole. You need to use bolts instead for alignment. I ran this pan for 3 races after the bad wheel stand. It didn't leak and held vacuum fine. I hope this answers the pm questions.
You have a PM Larry.
A second class drive is better than a first class walk. |
Sale Pending on the Moroso Langer Split-Rail Oil Pan
