Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Updated list
- Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $425 - GRP aluminum rods, set of 8 w 50 runs, 2.100 rod, .990 pin, 6.600 long used, $150 - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $80 - fluidampr Pontiac balancer, used, $250 - moroso 2 groove aluminum crank pulley 4" OD machined to fit above balancer, outer groove is dented, used, $30 - HVH super sucker SS4500-1.1 plastic 1" for 4500 dominator carb 2.125", used, $75 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $100 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - Barry Grant BG280 fuel pump, used, $150 - (3) Barry grant 4-port pressure regulator brackets $10 ea - 5-gallon poly fuel cell w -8 outlet and missing other outlet fitting, -8 retuen missing vent fitting, with mounting brackets used, $50 - Moroso aluminum 727 proflite trans pan w drain plugs, bottom side dinged up from wheel stands, used, $60 - B&M pro ratchet shifter cover, aluminum for 3-4 speed auto trans, new, $40 - Hurst quarter stick 3-speed forward pattern w cable, no knob, used $100 - Moser pinion support w bearing, large, used $75 - Autometer pro tech series playback box, used, $50 - Simpson cam-lock 5 way harness, black, great shape, out of date, $75 |
Updated list
- Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $425 - GRP aluminum rods, set of 8 w 50 runs, 2.100 rod, .990 pin, 6.600 long used, $150 - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $80 - fluidampr Pontiac balancer, used, $250 - moroso 2 groove aluminum crank pulley 4" OD machined to fit above balancer, outer groove is dented, used, $30 - HVH super sucker SS4500-1.1 plastic 1" for 4500 dominator carb 2.125", used, $75 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $100 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - Barry Grant BG280 fuel pump, used, $150 - (3) Barry grant 4-port pressure regulator brackets $10 ea - 5-gallon poly fuel cell w -8 outlet, -8 return missing vent fitting, with mounting brackets used, $50 - Moroso aluminum 727 proflite trans pan w drain plugs, bottom side dinged up from wheel stands, used, $60 - Hurst quarter stick 3-speed forward pattern w cable, no knob, used $100 - Moser pinion support w bearing, large, used $75 - Autometer pro tech series playback box, used, $50 - Simpson cam-lock 5 way harness, black, great shape, out of date, $75 |
Updated list
- Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $425 - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $70 - fluidampr Pontiac balancer w/, moroso 2 groove aluminum crank pulley 4" OD machined to fit balancer, outer groove is dented, used, $250 - HVH super sucker SS4500-1.1 plastic 1" for 4500 dominator carb 2.125", used, $75 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $100 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - Barry Grant BG280 fuel pump, used, $150 - (1) Barry grant 4-port pressure regulator brackets $10 ea - 5-gallon poly fuel cell w -8 outlet, -8 return missing vent fitting, with mounting brackets used, $50 - Moroso aluminum 727 proflite trans pan w drain plugs, bottom side dinged up from wheel stands, used, $60 - Hurst quarter stick 3-speed forward pattern w cable, no knob, used $100 - Moser pinion support w bearing, large, used $75 - Autometer pro tech series playback box, used, $50 - Simpson cam-lock 5 way harness, black, great shape, out of date, $75 |
Updated list
- Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $400 - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $70 - fluidampr Pontiac balancer w/, moroso 2 groove aluminum crank pulley 4" OD machined to fit balancer, outer groove is dented, used, $250 - HVH super sucker SS4500-1.1 plastic 1" for 4500 dominator carb 2.125", used, $75 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $75 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - Barry Grant BG280 fuel pump, used, $150 - 5-gallon poly fuel cell w -8 outlet, -8 return missing vent fitting, with mounting brackets used, $50 - Moroso aluminum 727 proflite trans pan w drain plugs, bottom side dinged up from wheel stands, used, $60 - Hurst quarter stick 3-speed forward pattern w cable, no knob, used $100 - Moser pinion support w bearing, large, used $75 - Autometer pro tech series playback box, used, $50 |
Updated list, its getting smaller
- Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $400 - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $70 - fluidampr Pontiac balancer w/, moroso 2 groove aluminum crank pulley 4" OD machined to fit balancer, outer groove is dented, used, $250 - HVH super sucker SS4500-1.1 plastic 1" for 4500 dominator carb 2.125", used, $75 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $75 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - 5-gallon poly fuel cell w -8 outlet, -8 return missing vent fitting, with mounting brackets used, $50 - Moroso aluminum 727 proflite trans pan w drain plugs, bottom side dinged up from wheel stands, used, $60 - Hurst quarter stick 3-speed forward pattern w cable, no knob, used $100 - Moser pinion support w bearing, large, used $75 - Autometer pro tech series playback box, used, $50 |
- Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $400 - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $70 - fluidampr Pontiac balancer w/, moroso 2 groove aluminum crank pulley 4" OD machined to fit balancer, outer groove is dented, used, $250 - HVH super sucker SS4500-1.1 plastic 1" for 4500 dominator carb 2.125", used, $75 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $75 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - 5-gallon poly fuel cell w -8 outlet, -8 return missing vent fitting, with mounting brackets used, $50 - Moroso aluminum 727 proflite trans pan w drain plugs, bottom side dinged up from wheel stands, used, $60 - Hurst quarter stick 3-speed forward pattern w cable, no knob, used $100 - Autometer pro tech series playback box, used, $50 |
Updated list,
- Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $400 - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $70 - fluidampr Pontiac balancer w/, moroso 2 groove aluminum crank pulley 4" OD machined to fit balancer, outer groove is dented, used, $250 - HVH super sucker SS4500-1.1 plastic 1" for 4500 dominator carb 2.125", used, $75 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $75 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - 5-gallon poly fuel cell w -8 outlet, -8 return missing vent fitting, with mounting brackets used, $50 - Hurst quarter stick 3-speed forward pattern w cable, no knob, used $100 - Autometer pro tech series playback box, used, $50 |
John
would you consider selling the pan, pump and pick up separately? with the tall deck block the belt drive set up is useless to me Kevin |
Pick up is made for the pan and welded to the pump.
sorry i mis-read. was thinking pan, pump, pick-up AND belt drive, i thought that was awful cheap.
thanx tho |
Updated list,
- Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $400 - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $70 - fluidampr Pontiac balancer w/, moroso 2 groove aluminum crank pulley 4" OD machined to fit balancer, outer groove is dented, used, $250 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $75 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - Hurst quarter stick 3-speed forward pattern w cable, no knob, used $100 - Autometer pro tech series playback box, used, $50 |
Updated list and pricing
- Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $350 - Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $50 - fluidampr Pontiac balancer w/, moroso 2 groove aluminum crank pulley 4" OD machined to fit balancer, outer groove is dented, used, $250 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $75 - Mr gasket 4150 2" aluminum carb spacer, used, $20 - (2) Fram PH5 oil filters, new $10 pair - Autometer pro tech series playback box, used, $50 - Stock front and rear glass for 67-69 f-body, used, $150 |
Updated list
Updated list
- fluidampr Pontiac balancer w/, moroso 2 groove aluminum crank pulley 4" OD machined to fit balancer, outer groove is dented, used, $250 - Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $75 - (2) Fram PH5 oil filters, new $10 pair - Autometer pro tech series playback box, used, $50 - Stock front and rear glass for 67-69 f-body, used, $150 |
Updated list
what is the part # on the play back box?
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
I'll take the playback box. I will need your address again.
Thanks.
#39
Look on the first page of this post. My buddy Larry with the leathal dealz post is taking care of all of the shipping since I am working in tennessee right now.
#40
Updated list
- Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $75 - (2) Fram PH5 oil filters, new $10 pair - Stock front and rear glass for 67-69 f-body, used, $150 |
