Lower crank pulley
I upgraded to the 1969 setup (harmonic balancer, water pump, timing cover) as y'all recommended -- which all fits fine (you can see it on the engine pics I posted) -- but I need a new/different lower crank pulley.
Any vendor you can recommend? I've called 3 that don't have it
what water pump depth and pulley, AC or not, PS or not, and where did you get the balancer from? the crank has to match the others. two or three groove type with or without AC.
No AC in the car.
For a little more bling to your engine, you could see if this fits the bill...
http://www.ramairrestoration.com/cat...bf0b3e90282fba |
And which of those would I buy? Price doesn't matter .....
Call. You said you switched over to a '69 set-up. Is your water pump a 4" long unit? If so, you want either PSPS-69E-B or PSPS-69E-C ($289, Blue or Clear. You can ask if they have it in Black if you're looking for that option).
