Fresh Air intake Inconsistencies
Starting in 1973 the Trans Am hood scoops were closed. Yet, you could still get the ram air air cleaner on Formula's through 74'. Also, the 1974 GTO hood scoop was functional.
Why would Pontiac have fresh air intake on the GTO and Formula's but not on the Trans AM? I had read somewhere that it was due to some EPA noise rule. If that is true, how did the other's pass the rule?
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
EPA did have noise regulations. A 455 with a shaker scoop at WOT is louder than a 350 with the same scoop at WOT. That's the only reasoning I can come up with. The design of the Formula hood may muffle some intake noise, making them quiet enough to pass noise regulations.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
