Old 12-01-2020, 09:20 AM
Default '67 Factory front disc brakes
I've got my '67 on the way. The previous owner has told me that the car stops fine and everything, but sooner or later the front brakes will have to be serviced or replaced.
Am I going to have any challenges with the factory '67 front discs with the 4 piston calipers? I went on RockAuto and saw that they sell the 4 piston calipers but not the rotors. If I have to switch out or otherwise modernize the brakes I will, but I'd rather avoid it if possible.
Old 12-01-2020, 10:56 AM
242177P's Avatar
242177P 242177P is offline
The master cylinder isn't original (no bleeders) so the LeMans might have been
upgraded to discs later in it's life. If that's the case, the common 69+ single piston
calipers were probably used.
Hate to say it, but this looks another thing that's going to test your patience...
Old 12-02-2020, 02:31 AM
Geoff Geoff is offline
The host sells 67 disc rotors.
