Old 12-01-2020, 02:51 PM
bigger=better bigger=better is offline
Default Bonneville fuel tank
Can anyone tell me if a 69-70 Buick Wildcat fuel tank will fit a 70 Bonneville? Or if some other full size sister will work?
Sent from my SM-G965U1 using Tapatalk
Never hold your farts in.They travel up your spine, into your brain, and that's where you get sh!tty ideas from.
Old 12-01-2020, 03:32 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
It will probably fit and function just fine, as would the rest of the '69-70 big car lines. The size and mounting straps will likely differ and require getting creative. As an example the '67-68 Impala tanks fit the Bonneville\Catalina line, but they are not the same size tanks and don't mount identically - though they can be made to work if functionality is the need. I would believe the Buick would be similar.
Old 12-01-2020, 06:13 PM
rustyrelic rustyrelic is offline
I haven't done it, so I can say authoritatively that it will work, but look at the string a few lines down: http://forums.maxperformanceinc.com/...d.php?t=844265
68 Bonneville fuel tank discussion
Old 12-02-2020, 12:02 PM
I suppose this is something a hollander manual could resolve...
Old 01-07-2021, 04:16 PM
Hollander show different part numbers for all the sister models
Old 01-08-2021, 01:17 PM
north north is online now
Unlike the smaller A bodies the 65-70 B bodies each division had unique frames and chassis'. For example the Pontiac ran the exhaust inboard of the frame rails and the chevy had exhaust pipes outboard. The Pontiac gas tank is rather long and quite narrow because of that.
Olds and buick fullsize car tanks are also visibly different from each other.
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
