Old 04-18-2020, 06:18 PM
Dragncar Dragncar is offline
Originally Posted by 3fastgtos View Post
Dave made both intakes.
I might make the most N/A power(that’s the goal) but will not get the N/A record. Wrong car for the job. It’s a real titled ‘68 Firebird, steel shell, small tire car. It’ll probably come out weighing about 400lbs more than the current ex pro stock record holder.
SD
I am hoping that you do just that. The folks can work "backwards" sort of based on your NA record if you make it. Toned down a tad, water jackets on gas.
It might start a whole new avenue for Pontiac die hards. Racers will get the added benefit of longer head gasket life, RAV ports without tubes in the way and still take a Pontiac valve cover with inline valves.
Dave said he could add cooling to the heads and make them sized for any ci engine.
Hopefully they take off with enough interest to get them cast with real water jackets down the road. He told me how expensive that deal could be.
H&MRAVTTFMF!
Old 04-19-2020, 01:38 AM
Brian Baker's Avatar
Originally Posted by Scott Stoneburg View Post
Very nice looking. Looking forward to seeing the performance of it.
No water in the heads or block?
From the looks of it, no...this looks like it's either going alky or they're gonna' tip the can.
Old 04-19-2020, 03:49 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Wow!
But... I've gotta ask... what on earth is that VERY TALL head on the bench behind it? And what sort of chamber shape?
Old 04-19-2020, 06:38 AM
Mark G Mark G is offline
Congrats to all engine is killer..
Old 04-19-2020, 09:24 AM
Darren 639's Avatar
Darren 639 Darren 639 is offline
Looks like BBC airflow research cylinder heads in the background. Also there is a bench work extension on the front and rear of that cylinder head so I suppose they’re not as tall as they look. I definitely could be wrong.tho LOL
Old 04-19-2020, 09:33 AM
Darren 639's Avatar
Well as usual I should think before I speak. I thought it milled AFR on the cylinder head (the one on the bench ) don’t want to be that jackass that doesn’t respect the great accomplishments made. Sorry
Old 04-19-2020, 10:08 AM
Kind of looks like a Allen Johnson logo to me. Being a super charger inspired looking shop that would fit in.
Old 04-19-2020, 10:46 AM
slowbird's Avatar
slowbird slowbird is offline
Very cool build
Old 04-19-2020, 11:10 AM
3fastgtos 3fastgtos is offline
Originally Posted by Jack Gifford View Post
Wow!
That’s an AJ hemi head. This is in the Fowler Superchargers shop. Jeff Fowler bought Kobelco years ago. He has a full machine shop and specializes in tractor pulling engines.
Can you imagine ordering 5 hat to pan complete engines?
Jeff services the hemi in the promod I drive, that’s how I know him. I put him on this task about a year ago. He designed and built the timing cover.
After this I’m not sure he’s a Pontiac fan lol.
But he is a funny car fan. He won a couple world IHRA championships in his day.
SD
Old 04-19-2020, 01:14 PM
Stan Weiss's Avatar
SD
Steve,
Are you sure? Does not look like any Hemi I have ever seen. It look more like a AJ 481X to me.
Stan
Pontiac Pump Gas List
Old 04-19-2020, 01:22 PM
Steve,
Stan
Yea you’re probably right, I was assuming hemi since it said AJ on it. I forgot about the 481X. I live in a bubble.
Old 04-20-2020, 12:39 AM
Thanks for ID'ing the AJ head.
