#81
Hooray for Gary!
#82
LMAO..... Wait til you get yours back together Charles.
#83
Hey Paul, thanks for posting this! I just got a new aluminum radiator that sits a bit lower than stock. I'm sure I would have had the same problem had I not read your post.
Cheers, Sammy
Sammy 1967 Lemans: 455 swap in progress (stock crank, stock rods, TRW slugs, mildly ported 6x heads, Stump Puller hyd roller, 1.5 PRW aluminum rollers, Comp hyd roller lifters, Performer RPM, q-jet, RA exhaust manifolds, 2 1/2" exhaust, ebay HEI), 200 4R, and some suspension stuff |
#84
You're welcome; however, the big thanks go to ScreamingChief for that excellent tech tip and GT182 for telling me "hey Paul, you should make a separate thread with that info!" I'm still not convinced my $$$ aluminum radiator on the LeMans is any better than my standard 4 row desert cooler on the Firebird...they both run at the same temp!
The Firebird, GTO & LeMans are gone...the garage is now occupied by 2005 Porsche 997 C2S and more guitars in the house... |
#85
Of course it's better, it's probably about 15lbs lighter! Crap, by the time I'm done with my Lemans, I'll probably have shaved off an easy 100+ pounds from the front end (aluminum radiator, aluminum intake, no more a/c, etc).
Only problem now, is I'll have to fab up some new brackets to raise up the radiator a bit. More work!
#86
Temp Sending Unit Line Too Hot, Gives False Temp Reading
I was out to a cruise night this past Saturday and was talking to a few guys that have been having over heating issues too. One of guys suggested wrapping the line for the temp sending unit in the intake back to the firewall. Reason being the heat from the water crossover and engine will mess up the temp reading for the gauge, the mercury in it will pick up heat and give a false reading.
That's one I haven't heard before and kind of makes sense. Tho I'm not sure if it true or not. Has anyone done this, and what would you use to wrap it and keep it cooler?
#87
Gary
I'm sure Coolio could rap it! Ok, that was weak, I know...
#88
LMAO.... I know BC, yer havin a bad day. Well me too, still raining here and I'm about ready to put pontoons on the Goat.
#89
Nah, having a much better day today than yesterday!
So, things are looking up! Sorry to hear about the rain, we sure could use it out here! Why not build the baddest amphibi-goat, like the blokes on Top Gear did? That would be cool...
#90
BC I'd love to send ya some rain. AmphiGoat... no thanks. I don't need the saltwater on it, nor the polluted crap they call water in the streams and rivers here. Besides, I've never seen a Goat that could swim very well.... amphibleous or not. LOL
Sounds great things are finally coming along with your LeMans, 'Bird, and Goat.
#91
Two 1975 455 Grandvilles & '79 455 Trans Am ‘69 Camaro SS 396/375 (owned since ‘88) ‘22 Toyota Sequoia V8 ‘23 Lexus LS500 awd ‘95 Ford F-super duty 4wd 7.3 p-stroke & countless Jeeps & off road vehicles. |
#92
actually, aluminum doesn't dissipate heat better than copper/brass. an aluminum radiator (because of the structrual ability to have wider tubes) does dissipate heat better than a copper/brass radiator, fwiw.
John J. |
#93
How much hotter?
#94
To the top...
Hey Mods - can we make this a sticky?
#95
Quick update; my GTO always ran a tick above 190*. I cut down the radiator hose and swapped the thermostat with a 160* that also had a small hole (1/16"?) drilled in the outside flange.
Drove the car today and yesterday around town, and the temp didn't even hit 190*! I'm stoked!!!
#96
Sounds good BC. By any chance is that a Stant 160 thermostat? I have a 180 sitting here that has the 1/16th bypass hole. Didn't help for me so I went with a Mr. Gasket High Flow 180 thermostat. Sure is pushing more water thru the radiator now. Couldn't find a Robert Shaw stat around here, but found the Speed Shop had the Mr. G. Works very well so far.
#97
Gary,
I think it's a Stant but I'm not sure. I drove my GTO home today, 90* weather, 40 mile trip, traffic lights for the first 4 miles then stop and go (mostly go) freeway for 10 miles then wide open freeway the rest of the way. I was cruising at 75-80mph, and not once did my car get over 190*. I'm running 50/50 anti-freeze along with some Royal Purple crap that NAPA had. No problems, she ran cool the entire time! I'm wondering if this had anything to do with it... http://forums.maxperformanceinc.com/...d.php?t=603889
#98
Open scoops look cool, and I don't think it'll hurt having extra air flowing thru. I've thought about opening up mine up but to pull them off the hood would ruin the paint job.
Glad to hear she's running cooler. I added the green stuff that's like the Water Wetter. Don't know if it helps but hey... anything that will help lube things up in there has gotta be good. LOL
#99
#100
I've heard it helps, but you ask 10 different car guys one question, you'll get 10 different answers.
