Until you know how close the piston is to the deck at tdc, you are chasing your tail.
I did everything you are doing, yes a poor designed water pump impeller made it worse. But the cast impeller set up properly didn't fix it either. Speeding up the water pump helped, but ultimately didn't fix the problem. Pull a head off and see where you are before you spend more time doing things that only attempt to band aid the real problem. Rich
68 Firebird 400, #16, xe274, street dominator, 850 DP, hooker headers, t400, 3500 stall, 3.73, 295/65 bfg drag radicals... best 13.27 @ 102.8, 1.90 60ft |
i will wait to see what difference the stewart water pump makes before wasting more time on anything else.....
I think your 13 lbs cap is to light , your car would have come with a 15 lbs cap. 2 lbs will make a big difference in the temp.
ok i will check with my mechanic on this....
No, Rex is right. You need a 15# cap... cut and dried. Any less will cause overheating. Don't ask me how I know as I've been thru that too.
GT182 I thought Cardone was working closely with the Pontiac People at reworking their pumps, I have been following it on another thread , Have they dropped the Ball or is it just stuck in Upper Mgmt ?? I know some of you were having meetings with them or was trying to meet , Is there any light at the end of the tunnel yet
even if cardone rework a pump it will need some serious work in design from what my friend explained to me, no one commented on the stewart pump, i would think that as it pumps 55 gal a minute and stewart says it has shown a 300% increase on flow well if any of that is true then why bother messing around , this fits on the rad hose out of site easy install so i'm hopeing its the fix....anyway i will have it fitted soon so will know then...
As for Cardone like I've said before..... They have the correct impeller already done and on pumps. It's as correct as the ones Pontiac had made back when they first came out with the 8 bolt pump. All we need now is the correct part number for it so we can order them.
I spoke with my friend about going from my 13 psi cap up to 15 psi he explained what the cap psi does in detail and said it will make no difference changing caps...
Get him to take photos of the water pump... side view too.
me taking a pic of pump is not going to tell you much, when its installed and I drive then that's all we need to know, does it fix the issue or not....the pump is pictured on stewarts website ....electric pump model e558a
https://www.stewartcomponents.com/in...&product_id=69 |
2 things if you don't use the 15 lbs pump it will let air in to soon & it will over heat & if your guy says there is no difference je doesn't know what he's talking about. The higher pressure will keep the pressure up & it will have a higher boiling point. That is basic science. Also if you put another pump on your car that pumps water at 55 GPM you will be moving the water so fast it won't have time to cool down in the rad. As it will going through the system to fast.
rex just another thought on the cap, as u said it will overheat with just the 13psi compared to the 15 psi....well heres some figures i did.. A 13 lb cap will increase boiling point from 212* to 251* [ 3* increase per psi of cap pressure ]; so a 15 lb cap will raise the BP to 257.....well yes the 15 psi cap will raise the boiling point...BUT with the 13 psi i have a boiling point at 251....my car is never getting anywhere near 251 so changing to 15 psi is pointless it will do nothing....i dont need to raise boiling point any further its already higher than i will ever need...
Here we go again.......so if slow flow gets rid of heat faster, slowing down to zero flow must be the best.....unless, of course there is some sweet spot, meaning we need to run the engine at this particular sweet spot.........
Gang, this is all bunk, faster water flow, faster air flow will remove heat better....look at the manufacturer's heat transfer curves on ANY heat exchanger.....physics does not change. George
I was asking to see photos of the 8 bolt water pump with a side view of the impeller. Then we could tell if the impeller's contour is your problem.
Have fun with the electric Stewart water pump. I'm not trying to be a wise a**, but IMHO you're just wasting money and adding $s to your mechanics pocketbook. It's your choice. Good luck and I hope it works out ok.
#38
$450 for a water pump? |
#39
yes I know is a lot but I really don't care....if it don't fix it I have wasted more money and time....but if car runs at I hope around 180 all day long then that $450 will be quickly forgotten, wouldnt u agree.....
