Old 11-03-2020, 06:50 PM
72GTOMN 72GTOMN is offline
Default New 1971 LeMans sport convertible
Hello,
Today I picked up a 1971 Lemans sport convertible. It seems pretty original except for 1 repaint many years ago. Guy I bought it from has had it since 1988. Figured I couldn’t go wrong for the $5000 he wanted for it. I just started to look it over and it’s supposed to have a 350 2 barrel. I cleared off the engine code and it says YC which I think is supposed to be for a 455. So I’m confused. It still has s 2 bbl on it. Are all Pontiac blocks stamped with displacement on the sides somewhere?
Thanks!
ID:	553004   Click image for larger version
Old 11-03-2020, 07:16 PM
nice work snapping that up!
Old 11-03-2020, 07:57 PM
3 Chiefs's Avatar
3 Chiefs 3 Chiefs is offline
Your block should have the cubic inches cast into the block on the left bank, drivers side. It will be on the front side. Also on the passenger side behind the dipstick tube on the block. Drivers side is easier to read. If you think it is not the original engine you can also get the year of the block by looking at the block where the distributor goes in. There will be a two digit number referring to the year the block was cast. Let us know.
Paul
I never met an old car that I didn't like.
Old 11-03-2020, 08:26 PM
Well, a little disappointing. It’s a 400 YC code. I haven’t cleared off the date stamp yet, but I’m sure it’s likely a mid ‘70’s block with low compression. I think it’s only rated at 170hp if that’s the case. Oh well, still a pretty good deal.
Old 11-03-2020, 10:27 PM
3 Chiefs's Avatar
Heck yeah it is. Its a really nice looking car.
Old 11-03-2020, 10:30 PM
FrankieT/A's Avatar
What's he want for the red one?
Old 11-03-2020, 10:53 PM
The pic is in my garage. The red one is my ‘68 goat that’s my baby and not for sale, sorry.
Old 11-03-2020, 11:34 PM
67drake's Avatar
67drake 67drake is offline
You can’t drive both of them. I’d take that convertible off your hands, problem solved.
Nice score!
13.95 @ 102.1 on street tires @ 4055lbs.
Old 11-04-2020, 01:45 PM
Thanks! I’ll probably need to sell the Lemans this spring after I go through it and clean it up.
Old 11-04-2020, 09:02 PM
indymanjoe's Avatar
Money maker for sure. well bought.
Old 11-06-2020, 01:57 PM
grandam1979 grandam1979 is offline
What’s the head codes?
Old 11-06-2020, 02:12 PM
Tarl Tarl is offline
Screaming deal! why can't I get those.
Old 11-06-2020, 09:16 PM
Heads appear to be 4X
