Old 11-05-2020, 03:11 PM
lucky1 lucky1 is offline
Default 65 brake pedal return spring tab.
Anyone know a source or have a brake pedal return spring tab ?
“ that tab that attaches to the pivot pin on one end and connects to the
Spring on the other ?
Found a source for the spring.
Thank you.
Old 11-05-2020, 05:23 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Are you talking about this thingy?
Chris.
ID:	553083   Click image for larger version
ID:	553084   Click image for larger version
ID:	553085   Click image for larger version
Old 11-05-2020, 06:22 PM
65 421 TODD's Avatar
65 421 TODD 65 421 TODD is offline
Default Brake Pedal Pullback Spring Tab
If this is a picture of the part you're looking for, check this website link below. They have a description of it and some GM part numbers. They also have a spring along with a description and GM part numbers. I think this is where I bought my "tab" and spring, although they don't call it a tab, they call it a "Brake Pedal Pullback Spring Extension (R)". Good luck.
https://www.4speedconversions.com/3841645_r1.html
Name:	Brake Pedal Pullback Spring (2).jpg
Old 11-05-2020, 08:18 PM
Chris.
Yes.
Old 11-05-2020, 08:20 PM
Default Thank you.
Just ordered one. Thanks again.
