Old 11-07-2020, 03:35 PM
lucky1 lucky1 is offline
Default Brake pedal return spring.
It’s my understanding than 65’s with Manuel brakes had a return spring.
And that cars with power brakes did not. Is this true ???
If the spring was added to a power brake car, would it interfere with the
Normal operation of the power brake system ???
Thanks as always.
Old 11-09-2020, 12:39 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
There is a spring inside the power booster to return the pedal to normal position, so external spring is not required, putting a spring on it should not
change anything.
64 Lemans hardtop
4spd, buckets
