72 Choke coil part number
What is the correct part number for a 1972 455 HO Carburetor Stat coil or Choke coil? Is the HO different than the others? Thanks.
68 GTO Ram Air I Auto, Starlight Black/Teal-Survivor 68 Firebird Ram Air II 4spd, Aegena Blue/Black/Black 68 Firebird 400 Conv. Auto, Red/Parchment/Parchment 69 Firebird Ram Air IV, 4spd Matador Red/Black-Survivor 70 GTO Ram Air III 4spd Conv. burgundy(currently Black)/White/Black 71 GTO 455HO 4spd, Lucerne Blue/Black/Black 71 GTO 455HO Auto, Lucerne Blue/Sandalwood/Blue |
Here's a link to a visual. If your patient these come up every now and then at a much less cost. Plus they were used on many other models of Pontiac. They kill me with all the Hype just because it was used on the 455HO. As if it was exclusive to that engine. I realize a lot of parts were, but not everything.
https://www.ebay.com/itm/Pontiac-Ram...sAAOSwY75eAEDj
Ol' man Smith Pigeon Forge, Tn. Grand Rod Run Spring 2012 https://www.youtube.com/watch?v=DUIuGvWWthA http://s223.photobucket.com/user/fas...d%20Run%202012 Son video'd this... http://s223.photobucket.com/user/fas...a.mp4.html?o=0 |
Oops...Knew it was right for mine, ad said '72 also, should have verified that for your '72 prior to posting. Sorry about that. Glad you knew. Now I gotta find one just so I can see it and learn the difference.
No problem, thanks for the offer!
Sent from my iPad using Tapatalk
Interesting listing from a 3/73 Pontiac MPC, section 3.750. It shows there were 3 different possibilities, none of them specific to 455HO.
1st is #482127 for "All A, B, F, & G w/ H.T., 4bbl." 2nd is #487112 "All 4 bbl. (stamped 71-12)." 3rd is #487198 "All 4 bbl. (stamped 71-96)." Hope this is helpful. |
FWIW,...I have a spare '72 455HO which was assembled in late April '72 and it has the stat stamped 71-96 (which I just noticed is the last 4 digits of the part number). So perhaps the later build dates used this 487196.
Thanks for the additional info.
Sent from my SM-G988U using Tapatalk
In the Scotts quetion in the '71-72 A-body forum, I noted the following break down from the March 1972 Pontiac Master Parts Book: 487196 was the original choke thermostat used on '72 455 HO engines, 487196: -'72 all 4BC M40 with Y3, Y4, Y5 engine codes (late 72 model Dport 4bbl codes not in Pete's book) -'72 455 HO '__________________ Buzzards gotta eat... same as worms.
Thanks. What you found matches what is on my spare '72 HO motor. Wouldn't have thought that there would have been superseded parts in only one years time, but that appears to be the case.
Anyone have a picture? Just like to see one in place?
I guess this is it. http://forums.maxperformanceinc.com/...d.php?t=789140
Mike/Illinois Last edited by Judge273; 04-25-2020 at 09:55 AM. |
