#61
I've never been able to do that with a 455 Pontiac, even some more rambunctious Pontiacs with a 254/262 cam and 330 cfm conventional Eddy heads. They'll make a crap load of torque though. |
#62
I'm building a very similar set up but it has not been on a dyno yet either. 462, 10.5:1, 325 CFM E heads, 242/248 HR, Johnson short travel lifters, Crower 1.6 rockers, Northwind port matched, Sniper EFI.
1979 TA 541/T56 Magnum 1964 Catalina 462/TKO600 1965 GTO 389/4speed |
#63
Sounds like a really nice combo
#64
BTW, the Northwind was definitely holding back my combo, it had unusual cylinder filling for # 6 and # 8. My hood clearance would not permit a spacer, but if you can use a spacer some of that might clear up. Sometimes the throttle body EFI's don't like certain manifolds due to the way the fuel is dispersed- and this is a good example. The displacement is a typo- it's 467 CID.
1964 Catalina 2+2 4sp, 421 Tri-power 1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM, Holley EFI, DIS ignition. 1969 GTO 467, Edelbrock 325 CFM, Terminator EFI 1969 Firebird Convertible |
#65
Agree, nice combo. Looks like a nice collection of vehicles you have which car is it going in?
#66
The head porter has seen over 600 hp with the head/cam package. I just need to get a bit more tuning on this combo and push the mph up and drop the et.
#68
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
#69
Mine says 597hp for 127@3725. Guess calculator dyno's very just like real dyno's lol
#70
For us to make 600hp from 460'ish ci stock block pump gas friendly engines you'll need a very got set of heads and intake. An no cfm isn't everything when i say that. I bet most underperforming build are due to poorly done heads/intakes. Just because a piece of paper says the heads are good doesn't mean they are!!
#71
#73
I think it could easily be done with a set of wide ports or something of the sort without spending gobs of money. |
#74
Just need to get this one finished. Would love to see 600hp with this one but i think the rpm intake and no frills short block will hamper that |
#75
I'd love to hear more about the wideport build when you get that far.
#76
581 hp.
#77
Made up of used/spare parts mostly. Should be a fun/interesting build. I'll start a new thread once i get further along with it.
#78
10.76..thats with a mild convertor and gearing 91 octane and 16mpg..others with the same heads/cam have seen 20mpg
#79
Darin Morgan just went to work at BES this week. Quote:
https://www.enginebuildermag.com/201...ers-need-know/ Last edited by pastry_chef; 03-04-2021 at 09:09 PM. |
#80
Thread Tools | |
Display Modes | |
