Harmonic Balancer
Looking for recommendations on replacing the stock 1972 455HO harmonic vibration damper on my car. Is there an excellent quality replacement with the correct 4 bolt pattern so I can use the original pulleys?
Thanks for any input. Last edited by 4birds; 02-27-2021 at 11:51 AM. |
Powerbond makes an excellent street damper that also has degree markings #PB1056ST. I believe the same unit is sold by Pioneer in their packaging.
It also has the correct bevelled edge required for some A/C pulleys (which the SFI rated model does not). https://www.rockauto.com/en/parts/da...+balancer,5512
Michael Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done... Last edited by mrennie; 02-27-2021 at 12:01 PM. |
Stock or for racing specs?
Street use and occasional 1/4 mile "testing ". Max RPM 5500. Not a race car.
If you go on a track you need an SFI balancer to pass tech, so my NOS one is out.
The sponsor of this web site Ames performance carries a replacement one that’s SFIb rated one for $150, and it takes the 4 bolt pulleys.
They have the bolt and thick washer also and I would highly recommend replacing the bolt!
The Following User Says Thank You to Chief of the 60's For This Useful Post: | ||
SFI isn't required until 10.99 or quicker.
The Following User Says Thank You to 242177P For This Useful Post: | ||
Pioneer offers an SFI version. Have one on my own engine and have used a lot of them over the years with zero issues. We even used one on the last 505 we did here making almost 750hp and it has lived fine for quite a few years now.....
The Following User Says Thank You to Cliff R For This Useful Post: | ||
Second vote for the Pioneer SFI balancer
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
Romac
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
Thread Tools | |
Display Modes | |
