Old 03-01-2021, 06:14 PM
propuckstopper propuckstopper is offline
Default Delco DC12 Reproduction Battery
Greetings. I have a ten year old Delco reproduction DC12 battery that is finally starting to give up the ghost. I am pretty sure these batteries are constructed with a regular battery (lead acid or AGM) inside the reproduction DC12 outer case.
I had the thought of somehow trying to open up the outer case and replacing the actual battery inside. I have scoured the web trying to see if anyone has done this project successfully, but I couldn't find a thing.
It might sound like I am cheaping out here, but the fact is these new reproduction batteries approach $400.00 USD, plus shipping to Canada if that is even possible.
If I could get this outer case apart and do this project for a couple hundred bucks with a high quality battery, I would be all over it.
Has anyone here been through this project? Any tips or tricks?
I understand you can buy "toppers", but I would rather not go that route if I can "fix" this battery.
Thanks!
Old 03-01-2021, 06:29 PM
70GS455 70GS455 is offline
While i don't know for sure, I would start by opening up the bottom. That way any surgery would not be seen.
Sent from my SM-T817V using Tapatalk
Old 03-01-2021, 06:31 PM
Schurkey Schurkey is offline
Put a regular battery in the car, then shut the hood.
Old 03-01-2021, 06:46 PM
You sound just like my wife (after I told her a new one was $400.00)!
Haha!
Old 03-01-2021, 06:48 PM
That is what I was thinking, but I am a bit nervous cutting into the case. I realize that this whole thing might be too dangerous, but thought I would ask just in case there was a quick and relatively safe process.
The thing went together somehow, so my thinking is that there must be a way for it to come apart.
Old 03-01-2021, 07:46 PM
steve25 steve25 is offline
I am all for doing things that I have been called crazy for even trying to do, but non the less getting the project 100 % perfect and not minding the excessive time it took me, but this that you have in mind to do, even I would not attempt!!!!
Old 03-01-2021, 07:57 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Maybe try replacing the acid first.
Many vid's on You tube about how to do it.
Old 03-02-2021, 10:20 AM
To get to the acid, you would have to get to the internal battery. This, of course, means opening up the external case. If I could get the external case open, then I think it would be more logical to just replace the whole battery.
Old 03-02-2021, 10:34 AM
Bucksnort's Avatar
Bucksnort Bucksnort is offline
http://forums.maxperformanceinc.com/...uction+battery
This thread has pic of a repro battery taken apart - perhaps similar to the one you have?
Dan
Old 03-02-2021, 10:10 PM
Dan
Looks like he went in through the side of the battery...
