Caltracs arrived
Mr UPS man was kind enough to drop off brand spankin new caltracs.
Only issue- my Qa1's have an eyelet bottom mount and the lower plate has a stud hole. Ordered a conversion kit from Summit. Rear should be dropped off Friday, probably have it back in a few weeks. While the rear is receving surgery, I will sand and detail the underside of the trunk, wheelwells and repaint with eastwood chassis paint. John |
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
It's gotta be done
Yeh right, after 7 years she still does not understand the "car" thing.
I can not imagine being married to a woman that isnt into cars/racing.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton "Perpetual peace is a futile dream."-General George Patton "I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson "Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin |
I wish, I've been married for 9 years and my wife is jealous of the Ventura! She calls it every name that has 4 letters! LOL But I told her when I met her I'm into cars and in the end the car will still be here and I hope she is to. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! |
My ball-n-chain doesnt want to here, see, or discuss them...period.
Last time i mentioned something about one of them, she responded; "I dont give a dam about your cars"
Someone told me one time that I was lucky...........they must have been right My wife loves cars.......our first date we went to a car show. She loves drag racing, car shows and knows more about cars than some guys I know. She doesnt mind me spending money on the cars as long as I dont go overboard or spend more than we can afford to spend.........usually if I mention needing something she tells me to go ahead and get it.
She even had a Pontiac at one point before we met......a '79 Firebird Formula
ANY LUCK WITH CAL TRACKS
Have you had any luck with the cal track bars. If so call me. 864 - 276 - 7011 my name is james
Just painted everything underneath over the weekend, bewtween now and saturday I should be able to get everything in and mocked up so i can place the perches and set the pinion angle.
After that- tack the perches, bring rear back to fab shop to have ends welded on and spring perches finall welded and boxed. Then it will go to the machine shop to be set up. I looking at a full two weeks before the rear is ready to paint then reinstall. John |
Trouble
i need to know whinch hole to put the bar in the TOP or the BOTTOM. i am having 152 60ft times. and when i had the Southside machine bar it had a 140 60 Ft times. does it help to just keep tighting the bars up.
Call calvert
Rear was in, perches are located and tacked in place. Underneath is painted, offset hangers are installed, one tailpipe has been sectioned and repainted for added tire clearance.
Next is to have the gas tank narrowed 3 inches on each side, seal inside, repaint outside. This is a much bigger project than anticipated. Should be done in 2-3 weeks |
Rear is out being final welded. Got the new bottom spring plates from Calvert (for eyelet bottom mount). When mocked up I only had about 1.5" of shock travel. I made shock mount extenders for the bottom mount. Will now have 3-4" of travel.
Hope be moving under it's own power in a few weeks. |
Rear is all welded and set up. Axles need to go back to moser for an additional 1" of spline. Gas tank is being evaluated for the cost to narrow it.
Finally got all the required AN fittings to move regulator and mount external fuel pressure guage. Coming together slow but sure. It'll be together in time for the drag radial snow tires. |
Any updates?
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
Yes, rear is in car and painted. Axles are back, fuel system updates are complete. Bought a used set m/t 295 DR, had them swapped over. M/T appear taller than the equiv size BFG.
Waiting to here from gas tank guy who is narrowing my oem tank. I should have some time today to install backing plates and axles and test fit tires. I can also, prob. finish the shifter swap too, switched q-stick to megashifter. I think I might end up with a b&m pro ratchet. By this time next week it should be moving. Thanks for the interest. John |
