Old 06-26-2021, 10:17 AM
Vetteman61 Vetteman61 is offline
Default New A6 A/C Compressor, No More Remans
We have a '71 Catalina w/400. I've had multiple bad experiences with reman A6 compressors and want to get a new unit. Where are you guys getting your new A6s and what is your opinion on the quality?
Thanks,
Brandon
Old 06-26-2021, 10:23 AM
Cardo's Avatar
Cardo Cardo is offline
http://www.almaproducts.com/Transtar...ochure-(7).pdf Call Alma directly and talk to them to make certain you get the correct part number. Pulley, clutch clocking and pressure switch all vary. Then they had me order through a Thermo King up in Michigain somewhere ( I could probably find the reciept if you need me to) They build them per order, i had mine about 3 weeks after i ordered it. I thought the price was reasonable, it was about $120 more than a reman, about $450 total. No leaks or problems yet. I converted to r134a while i was doing it. Ice cold so far.
"I know just enough to keep me here, but not enough to get me out"
Old 06-26-2021, 11:45 AM
abefromen's Avatar
abefromen abefromen is offline
X2 regarding Alma.
Only issue is they use metric fasteners.
Old 06-26-2021, 11:51 AM
padgett's Avatar
padgett padgett is offline
Actually only matters in a show car. AC system does not care what compressor you use, HR6, Sanden, or even a York, does not matter to the AC.
Do have an A6 in the Judge because were available in the last century when I rebuilt the system.
Web Site
Old 06-26-2021, 04:44 PM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
hey Pagett, since it doesn't matter which compressor for 1971 car is any of the other options (HR6, Sanden, York) any better or more efficient to run than the original A6.
Jim
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
Old 06-26-2021, 05:23 PM
padgett's Avatar
Been a while but only real difference is the cubic inch displacement. More is better for low revs cooling. The A6 displaces about 12ci, DA/HR6 is about 10ci., Sanden is more like 9ci.
I have not noticed much difference between R12 and R134A in a well maintained system. Yorks are not for GM.
Web Site
The Following 2 Users Say Thank You to padgett For This Useful Post:
Old 06-26-2021, 09:50 PM
Thank you for the recommendations.
