I always thought (assumed) the scallop/not scallop distinction was specific to '63/'64.
K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 Last edited by Keith Seymore; 04-03-2020 at 09:58 AM. |
You mean non-scalloped?
For the 421 engine? From the many examples shown so far, it appears the straight deck of the 421 may have been changed with the new block casting in 1966 for the 421. (9782611) Also may have been some carryover blocks with the casting code 9778791 (which was used in prior years) in the beginning of the model year? (they were the straight deck)
I had a 1966 xWJ 421 engine in my 2+2 convertible. I will search through some old pics later today and see about the scallop or not. Should have some block pics in the restoration records. Wonderful engine BTW.
Looked through the pics I had easy access to. My block has the scallop on the right front face. I had about a dozen pics of the engine but not a single one with a clear shot of the block casting # or the casting date unfortunately. It was made on the day shift and that's all I could really make out. Tried a magnefine glass, still could not tell.
Had to go back to find a pic.
1966 GTO 1966 421-9.3-1 comp-Race Tec 23cc Pistons 1966 Tri-Power 1967 670 Heads Pontiac "Highlift" TriPower Cam by SpeedPro DUR 214 Int 224 Exh @.050 - 107 ICL LIFT .445" Int .465" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
Thanks!
The Following User Says Thank You to johnta1 For This Useful Post: | ||
I can’t seem to keep the attached pics from rotating.
They’re clearer though
I've got a '04 421 code 45B, the high HP Tripower version. The block is straight across as I thought all 421's were until this thread. My two '68 428's do have the wave in the casting in the area discussed above. Pictures attached.
One of these days, I need to figure out what to do with the 421. It is a short block assy. with valve eyebrows for later model heads. As you can see, it is bored to 4.185" from the original 4.093".. That's about .092" over standard. Is that OK with a '64 421?.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
The Following User Says Thank You to Dick Boneske For This Useful Post: | ||
Dick, I think the block casting code is 9773157?
The 3's can look like an "8". Looks like a nice 421 HO.
All 66 421,s were scallopped. 65 last year 421 that had straight deck
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of! |
The Following User Says Thank You to J GLASGO For This Useful Post: | ||
Thanks! Learning some new Pontiac Info on 1966 421 Blocks.
This discussion started, as many know now, years ago with the 1964 Royal GTO magazine article and Wangers/Schornack attempts to pass a 421 engine off as a 389 tri-power engine. Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
The Following User Says Thank You to 61-63 For This Useful Post: | ||
I have a 66 casting at .090 now. It still has an avg of .200 to .210 on the thrust side.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
The Following User Says Thank You to Mike Davis For This Useful Post: | ||
I know this is an old thread, I just wanted to add a data point, this is the WH block from my '66 421 My car was ordered November of '65, and has the 421 with the flat (non scalloped) block. The casting date, however, is pretty tough to read but could be 0205.
Thad 1958 Chieftain Safari (370,4 spd, 9 passenger) Daily Driver 1966 Bonneville Wagon (Factory 421,3x2,4spd, 9 passenger) On the road!! |
Even though the block only has 2 freeze plugs per side maybe at that point the foundry was starting the transition to the 428 block?
64 and 65 421 Blocks all seem to have the "flat" across the passenger side of the block.
I have seen quite a few of the 66 blocks with the scalloped block. More trivia. Only a expert like Keith Seymore or his dad would have the real knowledge on how the different plants in Pontiac worked. Tom V.
