Old 02-27-2020, 04:05 PM
Dick Boneske's Avatar
Default '76 Trans Am Air Cleaner
We need a factory style air cleaner for our '76 Trans Am, including the main housing, PVC connector, and whatever else is needed to make a complete assy. I've noticed you can buy the shaker scoop, but none of the air cleaner components.
This is for a 455 with a Quadrajet on factory cast iron intake.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 02-27-2020, 11:56 PM
Held for Ransom's Avatar
Dick, what year carburetor are you going to use? A '76 unit or the one from the '73 engine?
So long, farewell.
Old 02-28-2020, 01:00 AM
It’s a 7057274, a ‘77 Quadrajet.
BONESTOCK GOATS
Old 02-29-2020, 01:44 PM
I wasn't aware that the Trans Am shaker hoods were not functional Ram Air except for '70-'73. Strange that Pontiac did this--a hood scoop attached to the air cleaner just for appearance. Wow!
BONESTOCK GOATS
Old 02-29-2020, 01:57 PM
Years ago I had a ‘76 T/A 400 car, like many of them someone had removed the block off plate from the scoop and replaced it with perforated aluminum sheet.
In regards to the non-functionality of the closed scoop, just seeing that scoop move to the side with engine torque when you hammered the throttle was the coolest thing. So it did serve a function even with the scoop closed off, Pontiac Excitement!
Old 03-01-2020, 12:05 PM
78w72 78w72 is offline
sent pics of the air cleaner i have to your email.
