Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
WTB Holley Spread Bore Carb
WTB Holley carb p/n 6910
this is a spread bore 800 CFM carb with mech secondaries . ,dual fuel inlets , and a manual choke will consider other carbs but must be spread bore , mech secondaries , and dial fuel inlets |
eBay item number:
264655382627
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
I have a 650 mech secondaries, double pumper, 50cc rear. But single feed.
I think i have one. Ill check the numbers on it and let you know..
My Half AN Injun..... |
Do you need on that is ready to bolt on or are you looking for a good core?
either...... good core or bolt on is fine
I know a have a new one.... I'll see what else I have tomorrow
You have a new one? Didn't they stop making the 800 version years ago?
http://www.machdevelopment.com/album...775/527566.htm |
Hi Bruce, yes they did stop making them many years ago.
So what do you have? New old stock?
A new one that has never been used... and some used ones. You need one?
I might. Do you think the bowls and metering blocks from the 800 will work on the 650 version? I really hate the 650,s transfer tube and float adjustments and would like to convert a 650.
Yes they will interchange. I've never checked the calibration between the metering blocks. . I've convertered the bowls several times... To get rid of the fuel transfer tube and also to get rid of the "dual feed" bowls so it would fit under a shaker air cleaner assembly. Unfortunately the old school chrome dual feed lines are NLA and very difficult to find.
Paul K pm sent with contact info
Jeff |
Holley 6910
I have a very good (used) one with a Torker 1 for sale. $350.00 plus freight
What's the deal with the extra meter block?
I had acquired a 6498 (used) that had a 6910 primary metering block installed. I corrected that issue which left me with this one as an extra. So I offer it to the new owner of my 6910 which I have offered for sale. I also have an adjustable dual feed fuel line to go along with this 800 cfm Spread Bore, as well as a copy of HO Racing's Torker Tuning Secrets to make my package more useable. I also have a 6498, 6210 and other carbs, jets, metering rods, a RAIV intake, air cleaner misc. trannys, shifters, and so on.
