Old 04-05-2020, 07:37 PM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
Hi everyone, all issues resolved.
Ground strap missing from "std gauge" cluster over to mounting bracket. I make shifted a ground wire.
Clock started working.
Tried lights , they now worked and only turn on when lights are turned on, pulled light switch forward one notch. Dimmer works flawlessly.
The "2" wire lights system is only two wires for the clock. I was wrong that it had 3 grey wires. That may of been another thread though which I'll go update.
Here are some pics. I also fixed 2 lights in the dash cluster, top on the right side is for a light... the rest on rights side are for dummy lights.
In the middle of cluster on bottom is "BRAKE" light, above it is - dash light.
Then on far left, TOP is the "weird" light that has black wire go down to ashtray. fiber optic. it also works as a light. It's quite bright actually.
Also fixed heater control light, glove box light . Only one light left and that is gear shifter light! And...................... I'm done!!!!
What a great project. Thanks everyone!
ID:	536454   Click image for larger version
ID:	536455   Click image for larger version
ID:	536456   Click image for larger version
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
