I use KRE CNC 335 cfm Eddy round ports on the race motor. The new CNC chamber CNC ported RP heads I got from SD Performance are a work of art and flow up to 340 cfm, they will go on my next street motor.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
The Following User Says Thank You to AG For This Useful Post: | ||
I just had this motor refreshed.
- 535 IAII, KRE Hi Ports (360 CFM flow), Howard's HR cam, Vctor intake. 10.5 CR Used a quick fuel 750 on the dyno / 93 octane pump. In the car will be an EFI with a FAST 307603 Throttle body Last edited by nmoreilly; 04-11-2020 at 03:27 PM. Reason: Edit |
You didn't try it???
I've seen those kinds of gains with dominators, on BBC's, they seem to thrive on them. So I would have fully expected that a similar gain would have been possible on the 571 Pontiac, but it just didn't live up to the hype on this engine, and actually lost power and torque everywhere below 5,000 rpm compared to the 950 4150 size carb. Weird deal but that's why we test. |
I know, wasn’t an option. Bottom line though a motor like this with more cam, carb, head work, compression etc would be 900 HP +, just like your Dads motor - which I like a lot BTW !!
I think that 535 looks pretty damn good. Those number you posted are impressive, with a 750 carb no less. What a ball that will be on the street.
Every 500 plus cube roller motor I've run liked the 1150 at the track over 1050,. Tried 1250s too and seem like the 1150 was the sweet spot. Just my junk, mind u.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
The Following User Says Thank You to J.C.you For This Useful Post: | ||
Except for the Internal Linkage, there are very few things I would change on a good 1150 Dominator carb.
Jeff (Shaker455) builds a very nice 2 circuit Dominator carb. Most of the 3 circuit carbs work a lot better after being converted to 2 circuit carbs by Jeff, Tuner, and other qualified Dominator Tuners. The 3 circuit carbs were originally designed for Circle Track racing not Drag Racing or Street use. Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
