Old 04-03-2020, 08:13 AM
Keith Seymore's Avatar
I always thought (assumed) the scallop/not scallop distinction was specific to '63/'64.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 04-03-2020, 08:30 AM
You mean non-scalloped?
For the 421 engine?
From the many examples shown so far, it appears the straight deck of the 421 may have been changed with the new block casting in 1966 for the 421. (9782611)
Also may have been some carryover blocks with the casting code 9778791 (which was used in prior years) in the beginning of the model year?
(they were the straight deck)
Old 04-03-2020, 11:47 AM
mgarblik mgarblik is offline
I had a 1966 xWJ 421 engine in my 2+2 convertible. I will search through some old pics later today and see about the scallop or not. Should have some block pics in the restoration records. Wonderful engine BTW.
Old 04-03-2020, 12:41 PM
Looked through the pics I had easy access to. My block has the scallop on the right front face. I had about a dozen pics of the engine but not a single one with a clear shot of the block casting # or the casting date unfortunately. It was made on the day shift and that's all I could really make out. Tried a magnefine glass, still could not tell.
Old 04-03-2020, 01:31 PM
SD421's Avatar
SD421 SD421 is offline
What's the block casting code and date code on it?
Had to go back to find a pic.
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 04-03-2020, 02:10 PM
Thanks!
Old 04-03-2020, 03:31 PM
SD421's Avatar
I can’t seem to keep the attached pics from rotating.
They’re clearer though
ID:	536264   Click image for larger version
1966 GTO
1966 Tri-Power
1967 670 Heads
Old 04-05-2020, 12:39 AM
Dick Boneske's Avatar
I've got a '04 421 code 45B, the high HP Tripower version. The block is straight across as I thought all 421's were until this thread. My two '68 428's do have the wave in the casting in the area discussed above. Pictures attached.
One of these days, I need to figure out what to do with the 421. It is a short block assy. with valve eyebrows for later model heads. As you can see, it is bored to 4.185" from the original 4.093".. That's about .092" over standard. Is that OK with a '64 421?.
ID:	536382   Click image for larger version
ID:	536383   Click image for larger version
ID:	536384   Click image for larger version
BONESTOCK GOATS
'99 Bonneville SE Sedan
The Following User Says Thank You to Dick Boneske For This Useful Post:
Old 04-05-2020, 07:07 AM
Dick, I think the block casting code is 9773157?
The 3's can look like an "8".
Looks like a nice 421 HO.
Old 04-05-2020, 08:38 AM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
All 66 421,s were scallopped. 65 last year 421 that had straight deck
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of!
The Following User Says Thank You to J GLASGO For This Useful Post:
Old 04-05-2020, 09:14 AM
Tom Vaught's Avatar
Boost Engineer
Thanks! Learning some new Pontiac Info on 1966 421 Blocks.
This discussion started, as many know now, years ago with the 1964 Royal GTO magazine article and Wangers/Schornack attempts to pass a 421 engine off as a 389 tri-power engine.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
Old 04-05-2020, 09:27 AM
61-63's Avatar
61-63 61-63 is offline
I've got a '65 or '66 421 block that is .060 over and I'm going to take it to .090. I've had it sonic checked and it will be ok. So your '64 may be ok at .090 over but I'd have it sonic checked if it were me.
The Following User Says Thank You to 61-63 For This Useful Post:
Old 04-05-2020, 12:09 PM
Mike Davis's Avatar
I have a 66 casting at .090 now. It still has an avg of .200 to .210 on the thrust side.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
The Following User Says Thank You to Mike Davis For This Useful Post:
Old 02-23-2021, 09:53 AM
Teej's Avatar
Teej Teej is offline
I know this is an old thread, I just wanted to add a data point, this is the WH block from my '66 421 My car was ordered November of '65, and has the 421 with the flat (non scalloped) block. The casting date, however, is pretty tough to read but could be 0205.
ID:	561393   Click image for larger version
Thad
1958 Chieftain Safari (370,4 spd, 9 passenger) Daily Driver
1966 Bonneville Wagon (Factory 421,3x2,4spd, 9 passenger) On the road!!
Old 02-23-2021, 10:02 AM
steve25 steve25 is online now
Even though the block only has 2 freeze plugs per side maybe at that point the foundry was starting the transition to the 428 block?
Old 02-23-2021, 11:05 AM
Tom Vaught's Avatar
Boost Engineer
64 and 65 421 Blocks all seem to have the "flat" across the passenger side of the block.
I have seen quite a few of the 66 blocks with the scalloped block. More trivia.
Only a expert like Keith Seymore or his dad would have the real knowledge on how the different plants in Pontiac worked.
Tom V.
Old 02-23-2021, 11:06 AM
Tom Vaught's Avatar
Boost Engineer
Tom V.
Thread Tools
Display Modes
