Maybe someone stuck a banana up your tailpipe(s), or a mouse family moved in
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk 1.35 w/29.5x10.5x15 6.42 @ 109 10.09 @ 133 |
I think it’s more of the accumulation of neglect, slip shod work, and a novice to poor mechanic lol
Not sure what Pertronix you have,I have stuck with the original Pertonix 1.Been 20 years and have never had a issue.Have 2 in running engines,last one I bought still shows made in USA.FWIW,Tom
I’m not replacing it yet.. after a little research I figured out I’m missing the firewall to head ground strap, and the one from the body to the trans is original equipment.. before I replace anything that has to do with electricity I’m going to make sure I get the whole grounding situation fixed, also have a set of midd wires I need to put together to replace the summit ones
Because that's where the engine runs best, or because that's where you put them during your initial setting before the engine fired and ran?
In other words...sounds like you need some fine-tuning of the mixture screws, after you get some other issues figured-out. Quote:
That's not right. |
1.5 turns out: for initial set up
Top of sight window (I’m getting the terminology down): that’s where it was which I now have learned is not right. The needle and east was completely fouled, I replace both the front and rear. I spent hours on YouTube last night learning more about the carb.. hope it pays off. One question though.. when I rebuilt it the accelerator pump had a rubber piece, the original just had a little non on it and the replacement one has about 1/2 inch of thin rubber.. should I cut this so it doesn’t interfere with the float or should I get a different one? Thanks |
Tom V. ps "Post #21 "Maybe someone stuck a banana up your tailpipe(s), or a mouse family moved in" " I may have, in my lifetime, installed a pealed potato in a tailpipe, but installing a banana is a new one for me.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 05-18-2022 at 05:45 PM. |
You Save the skin because that’s where a lot of the nutrients are, lol!
Expanding foam insulation is my go to for complete nasty A holes that really deserve such .
I do stuff for reasons. |
Well I drainers the oil.. fortunately no coolant.. but it may have been better equal parts gas as it was oil.. lm letting it air out a little bit to hopefully evaporate what left before I put in the new oil..
I pulled the carb off, properly trimmed the umbrella on the accelerator pump, set the floats about midway up, replace the baseplate gasket (I had put one on that was too smal, and it kept the primary open and the transfer slots were way to exposed). Before I try to run it again I’ll verify spark on every plug.. If it floods again I may just get a new carb |
