Old 04-12-2024, 05:46 PM
Apache Warrior's Avatar
Apache Warrior Apache Warrior is offline
Default Question for the board
Anyone run 4.350 Ross pistons, flat-tops, for Edelbrock heads, .990 pin bore and a 1.420 CH or maybe somewhere close to this?
If you have the build sheet with the listed weights, can you share the ballpark average or a few of the individual weights?
Ross will typically ship a set with a +/- 2 gram delta across the full set.
Thank you.
