Old 06-20-2021, 08:15 PM
Pepi's Avatar
Pepi Pepi is offline
Default Negative Battery Cable Routing
Does anyone have pictures of how the negative cable was or is supposed to be routed? I have the assembly manual, but either the battery cables that are reproduced are too short or the routing shown in the assembly manual is incorrect. It shows routing up onto the fender, but there is no way the cable will reach, it would be about 6"-8" too short. You can see in the pictures if I run the cable high like it looks like the manual shows it is short and if I route it so it fits it is down close to the washer bottle.
Thanks,
Karl
ID:	568546   Click image for larger version
ID:	568547   Click image for larger version
Name:	Pontiac Assembly Manual Battery Cables.jpg
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 06-21-2021, 08:15 AM
How long is your cable?
The terminal should be down or a little bit down and to the fender.
(yours looks like it is pointing up?)
It also routes through a plastic loop on the fender which should let it have some more room.
Old 06-21-2021, 07:19 PM
Pepi's Avatar
John,
It appears to be about 24" from center of battery terminal to end of lug. I do have it pointed to the fender like the manual shows. Maybe the angle of the camera and the fact I have a tender hooked up to it and it is blocking the battery end of the cable.
The only plastic loop on the fender, has the wiring harness, washer fluid hose and I think the evap hose.
Thanks,
Karl
Old 06-21-2021, 09:37 PM
ladytata's Avatar
ladytata ladytata is offline
I have a real one out of a 73, I’ll try to remember to remember to measure it
Old 06-21-2021, 09:38 PM
Pepi's Avatar
Sounds good, thanks!
Old 06-21-2021, 09:41 PM
ladytata's Avatar
Getting old sucks, lol, here’s my number if you don’t have it 8473406638, remind me early morning
Old 06-21-2021, 09:57 PM
Pepi's Avatar
Will do. I believe I do have your number but if not I do now
Old 06-21-2021, 11:50 PM
Transamric's Avatar
Here's a few pics from my '73. The cables are service replacement parts from about 1990, but the routing matches the Assembly Manual and connects properly. Hope these lame pics are helpful.
Name:	73 TA neg cable #1.jpg
ID:	568582   Click image for larger version
Name:	73 TA neg cable #2.jpg
ID:	568583   Click image for larger version
Name:	73 TA neg cable #3.jpg
The Following User Says Thank You to Transamric For This Useful Post:
Old 06-22-2021, 07:54 AM
The Parts catalog showed the cable as being 25" long.
With Ric's pics, the negative may not have been in a plastic loop.
(don't have my 73 TA anymore)
Old 06-22-2021, 01:15 PM
Formulabruce's Avatar
My Pontiac Parts dept replacement is 29.5" circa 1977. That said; They liked to homoglate replacement parts to fit as many models as possible.
Old 06-22-2021, 01:39 PM
unruhjonny's Avatar
I have observed that if a person knows the part numbers, alot can be found on eBay.
1970 Formula 400
Old 06-22-2021, 02:15 PM
ladytata's Avatar
Stretched out its 22
Old 06-22-2021, 02:37 PM
Transamric's Avatar
Looked again to see if there was another hole in the inner skirt for a clip, as the PDM seems to show. But there isn't. To try to stretch it all the way up to the harness bundle retainer would make the cable way too short to reach.
The only other possibility is if there was originally a clip mounted to the rear-most washer bottle mounting screw (missing on mine), that may work with a proper length cable. The '72 PDM shows such a clip, #9782572.
Old 06-23-2021, 10:06 PM
Pepi's Avatar
Yeah, I tried to look for another hole on my inner skirt and could not find one either. That is the problem if I run it up to the large clip with the wiring harness, probably a good 6"-8" too short then. I wondered about the clip by the washer bottle bracket like the 72's also.
