Old 10-05-2022, 12:32 AM
Ramairnacho Ramairnacho is offline
Default Ac components and a c muffler hose clamps
I'm looking at my parts car and the ac lines to the a/C muffler are tightened with hose clamps will that work? Is that correct or where they crimped? My car is a 70 formula 400 auto
ID:	599969   Click image for larger version
Old 10-05-2022, 12:39 PM
dld's Avatar
dld dld is offline
They are correct for 70. and those are the correct style clamps
ID:	599993   Click image for larger version
Old 10-05-2022, 02:56 PM
Default Hac muffler insulation
Do you know where to buy a new a/c insulation foam sleeve and thanks for confirming its 70 too!
Old 10-05-2022, 03:34 PM
dld's Avatar
dld dld is offline
Original Air... is where i bought my stuff . they also reset my POA valve for 134 and upgraded my condenser
the hose and clamp kit they also have .
The foam I sourced from a foam shop on internet . don't remember site.
I only used pipe insolation for hose . don't like that much, may look for better product there.
ID:	600002   Click image for larger version
Old 10-05-2022, 03:41 PM
dld's Avatar
dld dld is offline
site
Old 10-05-2022, 09:56 PM
Default Poa
What's the poa valve
Old 10-06-2022, 04:41 AM
dld's Avatar
dld dld is offline
POA – an abbreviation for Pilot Operated Absolute – valves are suction valves used to prevent the AC system's evaporator from getting so cold that it freezes. In some air conditioning systems, this function is handled by a thermostat.
The Following User Says Thank You to dld For This Useful Post:
Old 10-06-2022, 02:05 PM
fbody_mike's Avatar
fbody_mike fbody_mike is offline
Someone please correct me if I am wrong, but the factory AC used the POA and this keeps the compressor running at all times while the AC is on. Other systems with a thermostat will cycle the compressor on and off to regulate the evaporator temperature. I recall there was some company making a conversion to swap out the POA to a thermostat system. There are pros and cons to both styles with wide temp swings or rapid cycling of the compressor being the main ones that can occur with the thermostat. I believe for the POA to work best you will need one compatible with R134A if you decide to change over from R12.
I built it one piece at a time and it cost me more than a dime.
Old 10-06-2022, 02:16 PM
dld's Avatar
dld dld is offline
that's correct . my post said I had my POA valve recalibrated. A/C will not operate correctly on 134 if you don't update the setting. this will cause the A6 compressor to cycle. These compressors take about 14 H.P. to run. That compressor cycling you will feel when driving . The conversion device shuts the compressor on and off.
a 70 car should have the newer condenser up graded to the newer F body design also
