Old 04-09-2022, 09:40 AM
Radman's Avatar
Radman Radman is offline
Default 1961 and 1962 Tempest turn signal cancel cam
1961 and 1962 Pontiac Tempest or LeMans. I now have a working 3 D print of the turn signal cancel cam. You will need to reuse the two metal tabs and the tension spring that are on the old cam. If you want one, contact me at Dcasteeljr@gmail.com I have tested this in my white 62 Tempest. Please not that the picture is with the tabs and tension spring installed on the new cam.
Name:	New cam tabs installed and tension spring..jpg
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 04-09-2022, 09:42 AM
Radman's Avatar
Opps, uploaded the wrong picture the first time.
Name:	New cam with tension spring installed on tabs.jpg
