Old 02-11-2018, 03:26 PM
Dick Boneske's Avatar
Default '62 Tempest Super Duy 195 Carb
I just rebuilt a carb with tag number 7019079, a Rochester 4 jet carb. The carb was either NOS or rebuilt by a carb rebuild company a long time ago. It had the typical white powder buildup between the airhorn & float bowl. The last picture is the "Before." Restoration went well, however, and it looks like new with new needle/seats, gaskets, accelerator pump, etc. Main jets are .057", secondary jets .069".
My concern is that it has no power valve. the bottom of the float bowl where the valve normally screws in is not machined, nor are the vacuum or gasoline passages.
Did these SD Tempests not have power valves?
ID:	475254   Click image for larger version
ID:	475255   Click image for larger version
ID:	475256   Click image for larger version
ID:	475257   Click image for larger version
Name:	Tempest 4 Barrel Before.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 02-11-2018, 04:02 PM
tom s tom s is offline
Dick,the SDs used a AFB carb.Tom
Old 02-11-2018, 04:19 PM
What was the option called that used the Rochester carb? The sites I checked for carb rebuild kits specify the Rochester 4 barrel for the 195 optional engine.
BONESTOCK GOATS
Old 02-11-2018, 04:35 PM
Just a 4 cyc 4 bbl engine,made quite of few of them.Tom
Old 02-12-2018, 01:24 AM
OK, they're not Super Duty, but an optional 4 barrel Rochester on a 195 4 cyl. Judging by the exhaust manifolds (split with two cylinders in each manifold), Pontiac was fairly serious about making some HP with this non-Super Duty engine.
My original post asked if these carbs should have a power valve. Does anyone know?
BONESTOCK GOATS
Old 02-12-2018, 09:27 AM
carbking's Avatar
carbking carbking is offline
The Rochester 4-Jet used on the 4-195 optional engine IN 1961 did not have a power valve.
This was changed for the 1962 model year.
Jon.
