Old 03-03-2022, 03:18 PM
highway star's Avatar
highway star highway star is offline
Default Master Cylinder rebuild kit?
Where to find a rebuild kit for a m/c '78 TA? Thanks!
Old 03-03-2022, 03:55 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is online now
Raybestos makes kits, but it will only fit on an original master cylinder. Need to find a Raybestos dealer near you.
Old 03-04-2022, 04:16 AM
Kenth's Avatar
Kenth Kenth is online now
You can have a new ACDELCO 18M1878 Master Cylinder at rockauto.com for $32.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-04-2022, 09:41 AM
TAKerry TAKerry is offline
FWIW
I have bought a couple at NAPA. If its a numbers matching thing White Post Restorations does a phenomenal job restoring them. No idea where to get a kit.
Old 03-04-2022, 03:40 PM
Yep, numbers matching, that's the second time I've heard "White Post", might as well do the prop. valve too, I'll inquire with them. Thanks!
Old 03-05-2022, 05:11 PM
RedDirtRoad RedDirtRoad is offline
I used White Post as well
Old 03-06-2022, 03:01 PM
Warren Seale Warren Seale is offline
The advantage of having it rebuilt is that they will install a stainless steel sleeve. Doing this will pretty much eliminate the need to deal with the master cylinder ever again due to corrosion issues.
79 T/A,WS6,403,A3
96 T/A,WS6 (#1344) ,M6
72 442,W30,A3
96 Vette convertible Grand Sport (#713),F45,M6
13 Vette 427 convertible (#1425),Z30/Z25,M6
Old 03-06-2022, 06:06 PM
Correct
I bought a rebuild kit and was going to do it myself but once I disassemble the MC I could see the sleeve was scored.
White post will machine the MC and install a new sleeve as Warren just mentioned
If your sleeve is good you are welcome to have my rebuild kit
Old 03-25-2022, 09:27 AM
I got the master cylinder & prop. valve back from White Post. Before installing I was reading in the GM manual about measuring the brake booster's piston rod measurement. They used tool J 22647 (go/no go gauge). I don't have the tool but wife pushed brake pedal & I measured the booster's rod when it came out, about 1 1/2". Will this be ok to activate the master cylinder? I had the booster rebuilt a few years ago but never thought to measure when I put it back in, I'm guessing the rebuilder assembled back to oem specs.
Old 03-25-2022, 10:50 AM
Push rod length needs to match the depth of the hole in the back of the MC piston. That's with brake pedal up/released.
Slim to none slack/end-play would be perfect. A hair short is better than a hair too long.
Way too short will make for a low brake pedal. Brakes may not lock down before the pedal hits the floor.
Too long will apply pressure/push-in on the MC piston when the pedal is up. A hair is ok as long as the piston seals don't cover or block the fluid intake/return holes in the bottom of the MC bowls.
Hope that makes sense
Clay
Old 03-25-2022, 10:59 AM
Ok, then I will measure the protrusion of the rod at rest and then measure the depth of the master cylinder piston. Eh? Thanks!
