1969 Grand Prix electrical fluctuation / Space Saver spare photos request.
Hello GP enthusiasts!
I have a question and request. Anyone have a GP who's electrical system fluctuates/oscillates? This is most apparent when cold then dissipates once warm but is still present. Also photos of how a Space Save spare is stowed, mounting brackets and trunk decals? Thanks! Alex |
fluctuates
have alternator diodes checked , tension on belt, battery post connections and ground straps.
Hmm . . probably the diodes then. All other related items you mentioned are good. Thanks for the response!
Alex |
Hi
I have the 69 GP SJ space saver tire and brackets and parts ...
it goes in the left /drivers quarter panel ... I should have taken pictures before I pulled it out...the car is gone now .. I think I have pictures of it before I stashed it this summer in the shed... Scott |
Yeah, I would like to have a look at the photos when you find them.
Thanks for the response! Alex |
space saver
from the trunk of a 69 Grand Prix
Scott |
Received,
Thank you! Alex |
Scott,
I'd be interested to buy or borrow the hardware brackets from that spacesaver. One of the businesses that I'm invested in is a laser cutting and forming business. We have a reverse engineering table so it would be fun to map them out and fabricate a few. Never enough demand to make any money, just for fun.
My Break Away Squad 1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
Thanks for the photo reference!
Here is my example of Space Saver spare storage. Already had the jack mast holster at the bottom, upper perch and threaded rod eyelet plate mounted in place. I used some flat stock and pipe to design the inflator bottle retainer bracket. I am not certain that's how this bracket was from the factory, but it is believable. The tire iron between the mast and spare also provides excellent stability. |
Hmmm . . Not sure. I did find a set of trunk trim panels in my car as you described. I will have to see if there is a slot in the LH panel to slip around the thread stock. There are a few finishing screws along the trunk floor flange that may have secured these panels in place. I'll photo and post in the next reply.
Thanks! Alex |
Trunk Partitions & Floor Loop for spare
I think when you ordered the Space Saver spare, that was all you got and no floor loop for a road tire. The loop on my floor is cut, from the factory?
The floor hook's threaded portion is straight, several inches long and the wheel is face down with the jack foot used as centering clamp. Here are the trunk partitions I found in my vehicle. I pulled the felt then soaked them with water to lay flat. Not sure if these are correct? They somewhat fit, but not really. |
I bought my 69 GP (model J) back in 1973 and it didn't have side trunk panels like yours. Mine were just a dark gray or charcoal cardboard that only covered the opening in the quarter panels. There wasn't any felt type material and there wasn't any material or cardboard that covered the wheelhouse. Panels were attached along the bottom with screws. After years of use they were looking shabby so I bought a set of what Ames said were exact replacements. While they fit somewhat like my originals they were not the correct material. If it matters my GP was an October 1968 build. The panels I found in the SJ parts car that had the space saver had only a right side and it looked just like my originals. Just curious as to when your GP was built. If later could there have been a running change in production where later cars got nicer panels like yours? Could your panels have come from another year GP like 71 or 72?
For what it's worth I recently contacted OPGI and they are sellling what I call "incorrrect panels". They sent me a sample of there material and it's not correct. Still looking for someone that makes the real thing. In the meantime are there any 69-72 GP owners out there that can let us know what your trunk panels look like? Last edited by 1969GiPper; 12-23-2015 at 08:49 PM. |
So...
is there a way you could send a decent pic of one of your originals to my e/m address? I'm about to go thru several 40 year+ collections of Pontiac parts helping some friends whose priorities have changed. If I know what I'm looking at it would be a plus for everyone involved. Thanks. I've always loved GP's from our '63 to our '67 and my '69 4-speed/air to the 'triple-black '76 SJ that I waited 8 years for my Mother to finally sell to me. She finally got tired of guys following her home from work wanting to buy the car. How often does that happen nowadays? jegstek@netscape.net
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
Do you have the trunk right side quarter trim panel and if yes can you supply a picture? Is it the original panel? If I can find it I'll supply a picture of that rectangle shaped black pad. |
This car did not have the right side panel when I got it but I did find a left side and a right side from a previous car in the garage. They are mirrors of each other. Will attach pics. Here are measurements as best I can tell. Width at widest place = 29.5 width at bottom of top flap = 21.5 width at top of top flap = 10.25 Height (unfolded) top to bottom = 26.5 Top flap = 10 inches height. Base = 16.5 inches tall. Side facing qtr panel = tan, side facing trunk = dark green.
