TCS ohms
How do you test a TCS Switch? I've tried 6 switches and all have read open. The car I'm working on is a 70 GP.
The temperature TCS switch or the tranny TCS switch?
Basically neither have an 'ohm' rating. It would be either open or closed. (the temp switch would use temps to open/close) Try this link: TCS Test
Ok that makes sense. Thank you. Now where is the rally gauge temp sender? I must be missing something. The gauge doesn't move off 100 degrees.
Sender for gauge is left of thermostat housing,green wire I think
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet Th400 gone. Tkx close ratio with .64 of 66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque wife sold it |
Thanks for the info, so from what I gather the TCS Switch is also the temp sending unit. Yes the green wire goes to the gauge. When the green wire is grounded out the gauge needle goes all the way to 260 degrees. If the TCS Switch doesn't have a resistor in it how does the gauge work?
Off-hand I would say there are 2 senders especially if it has a gauge and not an idiot light?
(I would have to look it up) Usually one unit is on either side of the thermostat housing? (I think?)
Read this thread:
70 Gauge Unit PS: PM Peter Serio from that thread, he can probably help you immensely.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates Last edited by johnta1; 06-07-2016 at 03:17 PM. |
