Old 02-01-2020, 03:13 PM
RA1John RA1John is offline
Default Distributor Hold-Down Bracket Finish
What was the original factory finish on:
1) Distributor hold-down bracket?
2) Bolt & washer?
- Inline Tube sells a black phosphate bracket & silver zinc bolt/washer.
- Some say bare metal, painted engine color
- Some say silver zinc plated
- Some say silver cadmium or silver phosphate
Since Distributor was installed at engine assembly plant before paint, it would make sense that the base of the Distributor, hold-down bracket and bolt would have at least had some engine color over spray on it.
Anyone have pix showing original finish on these parts?
'64 + the same process & finishes or...?
Thanks!
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
Old 02-01-2020, 04:03 PM
dataway's Avatar
dataway dataway is offline
To me they always appeared engine painted bare metal ... often there is enough oil back there to keep them from rusting and I don't think I've ever seen a phosphate or zinc finish on one.
Looked through all my photos ... don't see one of a factory line with dizzy clamp visible. Someone has to have one.
Old 02-03-2020, 11:27 AM
I could have sworn that I've seen pics from the factory recently that showed a bolt-in round plate that filled the distributor hole. The plate was painted engine color giving the impression that it was there when the engine was painted.. I'm trying to remember where I saw it. As for me, I blasted mine, painted it aluminum and called it good.
Old 02-03-2020, 01:12 PM
dataway's Avatar
I blasted mine and zinc plated it. Hopefully I won't have to look at it very much
Old 02-04-2020, 03:10 PM
GregP GregP is offline
Previous threads say they (Bracket & Bolt) were on the engine when painted and the distributor added after.
