I can send pictures if needed. Thanks
Rear bumper brackets frame to inner brackets. Left is bent a little but repairable. -$20 Harmonic balancer-$10 Trunk latch assembly missing one bolt-$10 Aftermarket front park light/turn signal sockets - $5 Rear view mirror bracket and black cover- $10 New aftermarket window cranks -$15 Rear seat ash tray -$5 Ignition coil bolt and strap (AMK G-7638)- $5 Throttle bracket to intake (AMK G-7628) -$5 Seat side panel screws (AMK- G-6656) - $5 Seat back panel screws (AMK G-6654) -$5 Water neck bolt and hardware (AMK G-7594)- $5 Hood scoop insert fasteners (AMK G-7410)- $5 Console bracket screw kit (inline tube #INL12497)- $5 Heater hose clam kit (inline tube #INL10500)- $10 Valley pan bolts (inline tube #INL10128)-$5 Radiator hose clamps (#INL11303) Starter wire heat shield non ram air- $10 Hood release assembly (release lever attach point is bent) $5 Console lid hinge -$10 Headlight bulb retaining ring - $5 Center console mounting bracket - $10 Fuel pump (unknown condition) Headlamp housing - $10 |
I know this is old but is the console hinge still available?
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot 1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD! 1964 421 GP-Sold 6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold |
It is actually. Would you like me to send you a picture of it?
Do you have the throttle bracket?
Throttle bracket to intake (AMK G-7628) -$5 Is that for a 70 GTO ? I’m looking for a 4 barrel throttle bracket for my 69
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Here’s what I have. This should fit a 70 GTO but you probably need to double check that. Thanks
