Old 05-21-2005, 01:53 PM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
ok i turn off the engine and some smoke comes off, as most of you guys can see the exhaust isnt on ive been waiting for over a month for my super compe to come in.
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-21-2005, 01:56 PM
can anyone tell me what i can do? do i have to put a screw in it?
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-21-2005, 05:31 PM
Measure the hole and install a small core plug.
Old 05-21-2005, 06:50 PM
67vertBird 67vertBird is offline
That is the A.I.R. injection port machine hole. It should be tapped I beleive. Just put a plug in it.
67 Firebird 400 Convertible (sold)
Old 05-21-2005, 07:57 PM
what exactly is the A.I.R. Injection port mqchine hole?
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-21-2005, 09:39 PM
Emission stuff,used an air pump with it.
1967 was the last year for that.
You don't need it, so I'd plug it.
Old 05-21-2005, 10:25 PM
sweet, only reason i took it off was because i kne w it was taking up at least 5 or more hp not knowing what it w, but i knew it would be ok because theres o lot of FB's without it.
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-21-2005, 10:29 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Osvaldo:
what exactly is the A.I.R. Injection port mqchine hole? </div></BLOCKQUOTE>
A.I.R. is the Air-Injection-Reaction system. The port leads to a small opening in each exhaust port. The pump (when system was all there) pushed air (about 22% oxygen) into the hot exhaust, to help burn off hydrocarbon emissions.
Old 05-21-2005, 11:22 PM
so i made a big mistake?
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-22-2005, 09:24 AM
WallyB WallyB is offline
You don't need it, no mistake, just plug it.
Wally
Old 05-22-2005, 10:56 AM
Hammered's Avatar
Hammered Hammered is offline
Weren't the California cars the only ones that came with the AIR pump? I believe you can get some good money out of that pump from someone wanting to restore a CA car.
John
1967 Firebird Convertible Factory 400/4spd
Now 462/5spd Fuel Injected
http://1967firebird.atwebpages.com/
Old 05-22-2005, 04:32 PM
hmmm thanks a lot for the tip better put it inside, i just had it laying around.
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
