Need parts for rebuilding underdash harness
Have any of you rebuilt your own under dash wiring harness and/or replaced individual wires from end-to-end with the terminals? I don’t want to splice and the wires I need to replace are bad right up to the connectors anyways so splicing is not really an option. One end of the wires I need to replace is connected directly to a fuse clamp (see picture) and the other end has a special female blade terminal with a retainer prong on the backside that slides into a socket (see picture). I need the connectors/terminals and fuse clamps.
If these are available I would also like to replace the rest of the fuse clamps since they are rusty. I don’t mind doing the work and the parts if available should be fairly inexpensive. I am trying to avoid spending the $560.00 for a replacement harness. Need these parts for my 68 Firebird Do any of you know if and where these might be available? |
Mine looked like that and I had the same idea of rebuilding it. After learning that the block cost about $100, I decided to get a reproduction harness from M&H Electric Fabricators, www.wiringharness.com The spade connectors in your top two pictures are available from NAPA (GM R59 type if I remember correctly).
1967 Firebird Convertible Factory 400/4spd Now 462/5spd Fuel Injected http://1967firebird.atwebpages.com/ |
I agree with hammered. Get a new one from M&H. They are identical to the stock version. Better safe than sorry when it comes to an electrical short/fire ...
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
