Old 01-28-2009, 03:12 AM
pippintook pippintook is offline
Default Pic showing how the BOP Viton Seal rides on Crank
I am disassembling my 400. I used the BOP Viton seal. When I pulled off the rear main cap, the BOP Viton seal stayed on the crank (not sure if that is/was a bad sign). Anyway, I thought the seal staying on showed nicely how the seal works...thought maybe a few others might like to see this..
Name:	pic of BOP Crank Seal.JPG
ID:	155992   Click image for larger version
Name:	pic of BOP Crank Seal II.JPG
Old 01-28-2009, 02:05 PM
grivera's Avatar
grivera grivera is offline
I wonder if the halves glued at the ends is what kept it in place? Did you have any leaks back there?
Old 01-28-2009, 02:21 PM
67cruiser 67cruiser is offline
Unless i am wrong , the directions say , when assemble is ready keep halfs together, and let the red silicone dry for 24 hrs , at least, So why did you take it apart??? Won,t seal this way, i had i believe .020 sticking up on one half, checking with depth mic, then i put a good drop of silicone in the corners and let it dry overnite. If its not ready for assembly why did you go thru this?? Confused.
Old 01-28-2009, 02:25 PM
ok, disassemble same thing, you should be ok, as long as you follow the instructions, did you use silicon down inside when you set viton seal into the cap?? Think your ok.
Old 01-28-2009, 02:42 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
I've never had luck with those seals. my DCI graphite seal works like a champ though and MUCH easier to install.
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 01-29-2009, 03:34 AM
I am disassembling/tearing down/ripping apart my 400...I am not sure why the BOP seal stayed on...had a little leak when engine was running...some oil pan tabs/braces solved most of the leaking...I think the seal was ok as far as leakage. My rear main cap did not have anit-rotation holes (78 W72 400), therefore did not put any silicone in the anti-rotation holes. I did dab the ends of seal halves according to http://www.bopengineering.com/seal_instructions.pdf
Old 01-29-2009, 04:30 AM
440GP69's Avatar
440GP69 440GP69 is offline
X2!!!
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 01-29-2009, 05:46 AM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
X3 -Jim
Old 01-29-2009, 11:35 AM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
Pippintook,
Looks like a nice install, thanks for the pics. It confirms the the anti-rotation holes are not necessary to stop the seal from rotating, the design alone does this. And while there are a few blocks out there that are unable to use a lip seal due to geometry issues, I can say with confidence that these cases are few and far between. With no disrepect to those who posted here 99% of rear main leaks come from the install. This statement is from almost 10 years of selling, installing, and troubleshooting many thousands of rear main seals. IMHO the BOP seal is the best seal on the market for most applications.
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
Old 01-29-2009, 02:29 PM
GR8ONE68's Avatar
GR8ONE68 GR8ONE68 is offline
I used one on my 400 and again when I upgraded to the 455. No problems with either one leaking.
469 (455 + .060") with the Edelbrock RAIV cam, Ported 6X-8 heads with 1.77" exhaust valves, 100 cc's, "0" decked block for 9.3:1 static CR, Eagle 1.65:1 roller rockers, Edelbrock RPM manifold and Edelbrock 750 carb., 1.75" x 3.0" Hedman Headers, 2.5" flowmaster exhaust system with "H" pipe and Dynamax super turbo mufflers. 200-4R with a Continental converter, 3.07:1 12 Bolt Saf-T-Trac
Old 01-29-2009, 07:56 PM
goatnut's Avatar
goatnut goatnut is offline
Installed the BOP's in both my 400's no problem. No leaks period.
69 GTO Judge
69 Firebird Trans Am clone
76 Trans Am 400 4spd.
06 GTO M6 18's red/red - 1 OF 188.
09.5 G8 GT Stryker blue met. premium with sport pkg.
Old 01-29-2009, 08:04 PM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
So far, I have used a big journal and a small journal seal, neither leaked. My PAN leaked on one engine because I chose to not install the OEM braces on the back pan bolts. I bet a lot of "seal" leaks are actually related to something other than the BOP seal. I just ordered another for my current build. Thanks Wade for making a part we really needed. M/T
