Old 12-23-2009, 12:00 AM
ramair2 ramair2 is offline
b-man
superb reply thank you. i knew that the 4pinion 10-bolts were beefy. i didnt know how seemingly cheap the non bop 10 bolts were made (hence the -need- for a 12 bolt for higher performance applications).
follow on q....
in your opinion, what is a better/stronger/higher performance capable rear, the 4pinion 10 bolts (used on RA cars) or the chevy 12 bolt used on some first gen camaros?
Old 12-23-2009, 12:11 AM
Kurt S Kurt S is offline
Another option is the 70's 8.5 corporate 10 bolt. It's a pretty strong axle and easy to find.
Kurt S
CRG - Camaro Research Group
The Following User Says Thank You to Kurt S For This Useful Post:
Old 12-23-2009, 01:43 AM
-DA -DA is offline
well, i can have it for $1000. sounds good to me!
Kurt - i've designed a triangulated 4-link to replace my leaf springs; it's more of a satchell-link than anything... really i'm just tired of leaf springs though. and i'm definitely gonna go back through the design to make it bolt to the spring perch rather than weld to the axle tube; i'd hate to destroy something that could fit another build if i don't plan on keeping it forever.
on another note... what's the max splined axle a 12-bolt can fit? or is the weak link in the gearing? i.e. what's the 12-bolt's crux, sort of speak? if i build my dream poncho motor, pushing anywhere from 650-800 ponies, is it even practical to corral this power using a 12 bolt (without crazy housing mods)? please excuse my ignorance; all of my homework to this point has consisted of d60's and 9 inchers which i could care less about bracing and modifying. i'll do the reading if someone can just point me towards the right literature...
thanks everyone!
-Dave
- '67 Firebird 400 Conv't
Keep driving your prius, we need the gas.
Old 12-23-2009, 10:36 PM
Originally Posted by ramair2 View Post
b-man
follow on q....
The 12-bolt would be my choice between the two no doubt. The only thing I really don't like is the C-clip axles, but you can have one built using Ford housing ends to get away from using C-clip axles without having to resort to leaky aftermarket C-clip eliminator kits.
A great lower cost alternative would be the corporate 8.5" 10-bolt rear that's nearly as strong as the 8.875" 12-bolt, it even uses the same pinion bearing.
The 4-pinion 8.2" rear ends are really best left for restorations, even though they'll take some punishment.
Old 12-24-2009, 12:22 AM
If you're talking 650+ hp, I'd go with your D60 or 9".
If that's a ways off, then the 12 bolt will work in the meantime. Esp with an auto. Manuals are much harder on axles.
Kurt S
Old 12-24-2009, 12:51 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Anyone tried running a GM 14 bolt rear end in a first Gen? The 454SS guys are running over 1000hp with the stock 14 bolt rearend and it's holding up just fine.
The BOP 4 pinion rear axles are also forged.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 12-25-2009, 01:44 AM
The 14-bolt truck axle (used mainly on 1-tons, IIRC) is tough. Never heard of anyone running it in a car though.
Kurt S
Old 12-26-2009, 02:58 AM
-DA -DA is offline
shoot dang... why not go crazy?! i wanna see a full-floating, 8-lug 14-bolt sitting under a first gen! who cares about unsprung weight and rotating mass anyway?
-Dave
Old 12-26-2009, 04:22 PM
RAJ7395's Avatar
I'm not talking about a 8 lug 1 ton dually rear axle.
I am refering to the 14 bolt that came in the 1990-93 454SS Pickups. It's a 5 lug, not much bigger/heavier than a 12 bolt, and comes with the 1350 front u-joints, beefy axles, etc. The 454SS guys are running boosted big blocks that put out over 1000hp and this stock differential is holding up just fine.
Old 02-12-2010, 06:40 PM
zman1969's Avatar
zman1969 zman1969 is offline
Default 14 bolts
IIRC there are 9.5" and 10.50" versions not much selection for strong differentials
Old 02-12-2010, 07:06 PM
428RA4's Avatar
428RA4 428RA4 is offline
Actually the newest C-clip eliminate kits don't leak anymore. I can contest to it but I still put silicone on the back plate. No leaks guys~!
Old 02-12-2010, 10:05 PM
limejudge69's Avatar
limejudge69 limejudge69 is online now
PY member 'monzaz' has one for sale in the 'Performance Parts For Sale or Trade' section right now. It's a 14 bolt with 3.73 gears, ready to go.
