Old 12-18-2019, 06:15 PM
taff2's Avatar
taff2 taff2 is offline
I'd want at least a full season of passes if I use the MLS - probably 60-70 passes, I'm banking on my small bore and iron heads increasing the working life of them. I do use ARP headstuds with 1.00" diameter x .250" thick hardened steel washers - torqued to 120 ft lbs- and I re-torque head gaskets at least 3 times per season.(plus the once after initial fire up and cool down).
Charlie, here's a couple of pics of the old o ring cutter I made, it's a bit rusty after sitting for years and I've removed the Cobalt tool steel for some other job- but you get the idea.
ps, I'll get some pics of the dry deck/reverse cooling system on the weekend-the block is behind a load of other parts in my workshop.
Name:	U4 BOX,LOW ROLLER, WENZLER BOX 006.jpg
ID:	527015   Click image for larger version
Name:	U4 BOX,LOW ROLLER, WENZLER BOX 007.jpg
ID:	527016   Click image for larger version
Name:	U4 BOX,LOW ROLLER, WENZLER BOX 008.jpg
Old 12-18-2019, 06:26 PM
charlie66's Avatar
So you spun that thing by hand to cut the groove? Wow .. Thanks for showing that to me. Very cool..
Yeah if you can get those pics that wold be cool..
Thanks again!
My Half AN Injun.....
Old 12-18-2019, 06:37 PM
taff2's Avatar
Yeah, it only takes half a dozen turns to cut the groove to the .030" depth, cobalt steel is very hard-and Pontiac iron is very soft!
Old 12-20-2019, 05:12 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
For us future street boosted guys and stock heads running 8-12psi, I'd assume a Cometic with the water holes is ideal?
I've had better luck with a grooved oringed head vs a Cometic with an RA50 on a different platform so I'm curious on the Pontiacs.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
Old 12-20-2019, 06:50 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Been running aluminum heads d ports, for 4 years 8-12 psi, no head gasket issues. I run cometics.
Old 12-20-2019, 10:18 PM
firechicken's Avatar
firechicken firechicken is offline
Same...stock block KRE D ports Cometic with water 12 lbs on street and 20 psi at track for 6 years. Never even a retorque on arp studs. Maybe I'm just lucky but for sure I'm lazy...
Old 12-20-2019, 10:42 PM
JSPONT's Avatar
LMAO!! Me too but I do re torque a few times a year!! Yes ARP studs also with water. drive it all over.
Old 12-24-2019, 09:30 AM
taff2's Avatar
Charlie, here's the details/pics of the dry deck and reverse cooling mod
Pics 1,2,3,9 are the old block
4, 5 are the water outlets from block to 'stat housing/radiator
6 is the core plugs blocking water pump holes into the block
7 ,8 is driver side fitting where water from passenger head enters block
11 is fitting in heater nipple port where water exits rear of head and goes into side of block through an10 hose
12 is the stock crossover location where water from electric pump is fed into the heads
14 are pics of the plugs I used and part numbers. Large plugs are 3/8" NPT, medium are 1/4" NPT, small are 1/8" NPT. Drill sizes I used were .343" small, .500" medium, .625" large. About 60 holes to drill/tap/plug.
16 ,17, 18 shows heads dry decked too
19, 20, 21 shows me just starting on the 'new' block.
With the reverse cooling system - water gets pumped from the electric pump into the heads through the manifold crossover, flows through the heads to the back and exits from the fittings pressed into the heater nipple plugs, then through an10 hose into the side fittings in the block, flows through the block and exits at the front fittings through an10 hose into the thermostat housing or radiator.
I've got some pics of the hose routing somewhere, I'll dig them up when I get 5 minutes. Hope this helps you visualise what's involved.
Name:	PONTIAC DRY DECK REVERSE COOLING 001.jpg
ID:	527340   Click image for larger version
Name:	PONTIAC DRY DECK REVERSE COOLING 002.jpg
ID:	527341   Click image for larger version
Name:	PONTIAC DRY DECK REVERSE COOLING 003.jpg
ID:	527342   Click image for larger version
Name:	PONTIAC DRY DECK REVERSE COOLING 004.jpg
ID:	527343   Click image for larger version
Name:	PONTIAC DRY DECK REVERSE COOLING 005.jpg
Old 12-24-2019, 09:40 AM
taff2's Avatar
More pics
Name:	PONTIAC DRY DECK REVERSE COOLING 006.jpg
ID:	527345   Click image for larger version
Name:	PONTIAC DRY DECK REVERSE COOLING 007.jpg
ID:	527346   Click image for larger version
Name:	PONTIAC DRY DECK REVERSE COOLING 008.jpg
ID:	527347   Click image for larger version
Name:	PONTIAC DRY DECK REVERSE COOLING 009.jpg
Old 12-24-2019, 09:47 AM
taff2's Avatar
And more..
Name:	PONTIAC DRY DECK REVERSE COOLING 010.jpg
ID:	527349   Click image for larger version
Name:	PONTIAC DRY DECK REVERSE COOLING 011.jpg
ID:	527350   Click image for larger version
Name:	PONTIAC DRY DECK REVERSE COOLING 012.jpg
ID:	527351   Click image for larger version
Name:	PONTIAC DRY DECK REVERSE COOLING 014.jpg
Old 12-24-2019, 09:52 AM
taff2's Avatar
the pics keep on coming..
Name:	PONTIAC DRY DECK REVERSE COOLING 016.jpg
ID:	527353   Click image for larger version
Name:	PONTIAC DRY DECK REVERSE COOLING 018.jpg
ID:	527354   Click image for larger version
Name:	PONTIAC DRY DECK REVERSE COOLING 021.jpg
ID:	527355   Click image for larger version
Name:	PONTIAC DRY DECK REVERSE COOLING 022.jpg
Old 12-24-2019, 06:40 PM
charlie66's Avatar
Thanks Paul!
Ill have to make a folder and put all these pictures together for when im going to attempt this..
Old 02-18-2020, 07:06 PM
taff2's Avatar
Rusty or Bad69bird or any guys using Cometics WITHOUT water holes, did your gaskets have any water holes at all? I ordered the Cometics without any water holes using the part number that their sales guy gave me, however when they turned up they had two water holes in each gasket! These are the bigger holes at each end of the heads - leaving less than .250" of gasket material between the bore and the water holes - exactly what I didn't want! (these water holes are tapped and plugged, but there is still a 0.051" void that cylinder pressure could blow into)
I contacted Cometic who apologised and said they would make me a new set with no water holes at all, however, they have now said that these holes are used for the manufacturing die pins to locate the gaskets for embossing, and therefore I must have water holes in the gaskets that are listed as 'no water holes'. You couldn't make it up.
Old 02-19-2020, 02:50 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Any manufacturer who doesn't do all locating off the dowel holes is goofy.
Old 02-19-2020, 06:15 AM
taff2's Avatar
That's a good point Jack, how would they know where to punch out these two water holes if the gasket wasn't already located correctly?
I've put these points to them and I'll see what they say.
Old 02-19-2020, 06:33 PM
taff2's Avatar
Ok, Cometic got back and said they can't do a 'no coolant holes Pontiac headgasket' without having the two coolant holes in each gasket!
No answer on why they don't use the dowel holes for the locating die pins. S
So, any Pontiac guys thinking of buying solid gaskets for your dry decked combo, be aware of this. It may be a problem or may not, we'll see.
Old 02-23-2020, 06:27 PM
JSPONT's Avatar
I seem to remember, Sik Goat ( Billy) uses a head gasket manufacturer for there 6 second ride. I can't remember who it was off the top of my head. PM him, think it is a copper gasket.
  #38
Old 02-24-2020, 02:46 PM
bad69bird's Avatar
bad69bird bad69bird is offline
It's been so long since I ran Cometics, I honestly can't remember if the gasket did or did not have the holes in them after I dry-decked my junk.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
