Old 01-11-2020, 06:09 PM
Default Procharger P1SC Supercharger Will make
800+ Horsepower.
The unit is Brand New, Never had the special supercharger oil in it.
(Comes with the standard 3 bottles of supercharger oil.)
No pan modifications (drain to pan) required.
Comes with standard (3 inch 8 rib) Supercharger Pulley.
Comes with standard 8 rib drive belt
Typical price (between $2550 and $2750) is shown in the link below.
http://www.jpcracing.com/procharger-p1sc/
My Price $1950 (if you pay shipping with a Fed-X or UPS Shipping Label)
If you can't swing that deal, we can figure out the cost for shipping/insurance and
add that for your location in the USA.
Tom Vaught
ps Luhn Performance sells Pontiac Brackets for this supercharger.
John M and BAE just created a billet block for John, bye, bye 5.80s
Old 01-12-2020, 04:28 PM
I will answer any questions about this supercharger in this thread.
Info.
800+ STREET Horsepower.
1) Luhn Performance sells Pontiac Brackets for this supercharger.
I know that they make a driver's side mounting set-up.
Not sure about the Passenger side, talk to Mark about that stuff.
2) This supercharger will make 800+ HP with a simple Blow Thru Carb
type boost system. Same HP with a FiTech carb system should be possible.
3) The unit has a self contained Lubrication system that uses a sump style reservoir on the front part of the supercharger. This sump holds 3 bottles of special fluid for the Procharger Supercharger.
4) Some smaller HP superchargers come with a 6 rib belt to drive the unit.
This unit comes with a 3" diameter 8-rib supercharger pulley and a matching 8 rib drive belt.
5) Most Pontiac installations use a separate belt for just the supercharger.
6) The P1SC unit (even though it is rated 800+ hp) does not create a lot of heat on the street applications like a F-2 Procharger RACE supercharger.
This means you may be able to make lots of street HP without adding a inter-cooler system. A SNOW injection system may be all the charge cooling that
you need. 70bird with his turbo system uses a SNOW injection system.
Added the info from the street section post here.
Will try to remove the other post. Tom V.
So that will do for the basic info.
Myself, Mark at Luhn Performance, or Brian H could answer more questions
if you post them up.
Typically a supercharger system using a belt can be installed in a couple of days,
turbo systems typically take more time
Old 01-13-2020, 10:34 AM
New Price $1750
Old 01-13-2020, 11:55 AM
Scott65's Avatar
Scott65 Scott65 is offline
Tom. with the included pulleys, what kind of boost would this unit be making at 5500-6000 crank rpm?
Old 01-13-2020, 06:40 PM
There is ONE included Pulley, the Supercharger mounted 3.0" pulley.
If you had a 6" crank drive pulley then the belt pulley step-up ratio would be 2
(6 divided by 3 =2)
If the supercharger INTERNAL step-up ratio is 4.14 then 4.14 times 2 =
8.28
If the engine is running 6000 rpm then 6000 times 8.28 = 49,680
supercharger rpm which should be close to 12 psi of boost pressure.
(It depends on the rest of the engine what the boost pressure is.)
With a 7" crank pulley the supercharger would be turning 57,960 rpm.
Enough to make over 15 psi of boost pressure on the typical Pontiac 400 engine. Don't race Boost, go for mass flow thru the engine and wheel dyno confirmation.
Procharger advertising says that the P1SC supercharger has the ability to make over 800 hp on the typical engine at max supercharger rpm. Max Supercharger RPM typically 60,000 rpm.
Luhn Performance made 862 HP at 5300 rpm with a basic 440 cid engine on the dyno at 13 psi.
(Vortech Supercharger though).
Old 01-13-2020, 08:18 PM
brooknice brooknice is offline
I sent you a pm
Old 01-13-2020, 10:24 PM
I did not receive your PM but maybe you can reply to the PM, I SENT YOU,
a couple of minutes ago.
Tom Vaught
Old 01-14-2020, 10:07 AM
Nice talking to you brooknice, we will see if we can work this deal out over the next few days.
Old 01-18-2020, 01:35 PM
Last Price Drop then I will offer it to Luhn Performance.
Pretty sure when he owns it and sells it as part of a kit, the Supercharger price will be higher. Price for a few days is $1650. Supercharger is new.
Old Yesterday, 10:09 PM
Please remove item from the Parts for Sale
Cold Case Radiators
Cold Case Radiators is a Max Performance company that produces high end aluminum performance radiators at a price point that won't break the bank. Polished and stamped tanks. 2 rows of 1" tubes. Lifetime Warranty.
GTOG8TA.com
GTOG8TA.com is a Max Performance company that manufacturers parts for the 04-06 GTO, 08-09 G8, and 93-02 Firebird/Trans Am platforms.
