Old 01-22-2020, 12:23 AM
When I originally saw this post, I wasn't near my car and did not recall that the rivets were actually outside the VIN 'window' and aft of the opening.
My dash pad has been recovered at some point by an old school upholsterer. It actually has stitched seams...so it may have been a little overstuffed and may not push forward as far as an original...so you can see my rivets but just barely.
Old 01-22-2020, 01:46 PM
dataway's Avatar
dataway dataway is offline
Rosette portion is visible from the top side on my 68. Hard to believe they could be installed from the bottom ... aren't they blind rivets? The "stem" would be sticking up on the top if they were installed from the bottom.
Mine is still completely apart, I'll try to get photos above and below today.
Old 01-22-2020, 02:07 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
Here are 2 pictures from different project GTOs I own, both with dash pad removed ( you can clearly see where dash pad boundary is).
  1. One (Arlington car) shows rosette rivets on top - Burgundy car
  2. Other (Pontiac car) shows opposite. Note, former owner appears to have attempted to drill out the rivets - can see on far rivet in picture - Verdoro car
My guess is that, regardless of guidance at a give plant, the assembly worker did what was most expedient for them...
ID:	529448   Click image for larger version
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 01-22-2020, 02:34 PM
68gtoMN's Avatar
Don't forget that many cars had moisture issues at the base of the windshield where the metal dash meets the glass. I have seen more than a few cars who had repairs performed with the windshield out and then the top of the dash sprayed when done. Some do it "right" and others perform what they think "looks good". These are not always the same.
I would bet the car is as stated, just having had dash repair and repaint.
Good luck!
'70 LeMans Sport
Facebook Event
Old 01-22-2020, 04:00 PM
dataway's Avatar
Look at that, the stems are sticking up. Obvious installed from below. Probably depended on if "Joe" happened to be under the dash at the time ... "Bob" hands him the rivet gun and says ''Stick that on there for me Joe"
I wonder at what point on the assembly line the tags were added, at the body plant before it was mated to the chassis? Considering that some VINs are stamped on the firewall, that would mean they knew what body was going where way before it was mated with the chassis ... so I guess the VIN tag could actually be added when the upper dash panel was stamped, before it was even welded to rest of the body.
Old 01-22-2020, 04:14 PM
Stuart's Avatar
Stuart Stuart is offline
To avoid any future confusion on which posts were made in which thread, I merged the two discussions on this topic.
The Following 3 Users Say Thank You to Stuart For This Useful Post:
Old 01-22-2020, 11:13 PM
Mcronk Mcronk is offline
I think it safe to say most of the time the rivets are covered by the dash pad. Good point about rivets not being inside the "window". Here is a picture of my 68 Tempest Custom VIN tag. This car has 49,000 original miles.
Old 01-22-2020, 11:23 PM
Here's what may have caused some confusion for me. These 69 GTO VIN tags have rivets in a different and more noticeable place.
ID:	529581   Click image for larger version
Old 01-23-2020, 08:12 AM
Keith Seymore's Avatar
I recall having the rivet discussion in the past. My recollection is that the majority of the plants installed the rivets "down" (with the rosette portion on top) but that there was one plant that did it in the opposite directions for some reason (rosette on the bottom).
Perhaps in their process the windshield glass was already installed, forcing them to do it in a different way. In any case, I would not expect variation in the way it was done within the same plant.
VIN tags typically are installed in the first operation in the trim area. (ie, body has been built and painted, coming down out of paint into trim, well before the body is mated to the chassis).
K
'63 LeMans Convertible
'63 Grand Prix
Old 01-23-2020, 11:31 PM
Everyone thanks for the info. I learned some new things. I made an offer on the car in question but was not accepted. However I am better prepared to make the next purchase!
The Following User Says Thank You to Mcronk For This Useful Post:
