67 GTO Convt quarter window weatherstrip
How do you remove the rubber (vertical) weatherstrip from the rear-seat quarter window?
Slides up or down? Need to remove anything to access? 67 GTO convertible. |
mine just pulled down, kind of a couple of tabs bottom fits in. Take picture before removing .ordered new and replace.
still trying
Thanks, I can see the strip needs to slide downward, but I can't get it to slide out.
I don't see any 'clips' or way to release it. Any other clues? |
Success
Thanks for the help! I was finally able get them out...mainly just force using pliers for sliding it down once I could see the lower end was clear of the tabs. Didn't need to bend the tabs. (I really don't believe the tabs are meant to be bent.)
The passenger side was much more difficult and appeared (possibly) to have some adhesive. The driver side was easier to remove. The new ones are soft and easy to install. |
Yes, there glued in.
Thread Tools | |
Display Modes | |
